problem with Helix..
574.1
Try to create Helix spline, then a circle at one end of it...
could not use "tube" (tuber in french version), because instead of a nice spring, it goes direct from one end to the other one of the helix...
any idea ?
574.2 In reply to 574.1
Hi Naxos, I just did a quick test over here and it seemed to work ok for me.
Could you please post a .3dm file of your curves so I can see what might be happening to your version?
574.3
ok, tried once more : now it is ok...
sorry for that topic ;-)
another question : where can i find moi.ini under vista ?
574.4
ok, we need another param for "tube" feature : twist...
for ex. i 'tube' an 'N' text curve onto an Helix curve...
nice...
but the 'N' shape is a bit twisted along the helix, i guess it's from some banking stuff...
a twist param could help to get strait 'tubing', and also to model some very funny twisted stuff...
like greek columns forex.
574.5 In reply to 574.3
Try this: C:\Users\[your user name]\AppData\Roaming\Moi
574.6
thank you, you all shall try this :
http://moi3d.com/forum/messages.php?webtag=MOI_FRANCAIS&msg=13.1
regards.
574.7 In reply to 574.6
Also check out Petr's page at: http://kyticka.webzdarma.cz/3d/moi/ , he's collected several other scripts there.
