problem with extrusion
All  1-8  9-11
5733.9 In reply to 5733.8
BurrMan, you are right. Although I thought the curves were 100 % upon a XY planar surface, it is not exactly.
I projected the curves to a new XY-planar and used that new projection for extrusion. Now the whole problem is solved.
Thanks all for your help!
Raoul
5733.10
Hello,
Here is the zoom of défaults
-Kaël
Size: 359.6 KB, Downloaded: 47 times, Dimensions: 1680x1050px
5733.11 In reply to 5733.9
Raoul:
<<BurrMan, you are right>>
He is ALWAYS right...
Raoul:
<< I projected the curves to a new XY-planar and used that new projection for extrusion. Now the whole problem is solved>>
I use same trick in cases like this,where there are too many points to check if -REBUILT- not give results
i think in this case -REBUILT-has cutted away not-planar points...
Show messages: All  1-8  9-11
