How To : construct cylinder with rotated grid
All  1-2  3-6
Seems like flow would work well. Use "Unwrap" script to get circumference of cylinder for 2 sides of rectangle. Use height of
cylinder for other two rectangle sides.
Helix with rotation copy, may work also?
Helix with array?
Here are my first 3 attempts.
Make square, separate, flip 2 opposite sides, select 3 sides and lineweb.
Select 4th side and one adjoining side, lineweb, repeat to finish grid.
Delete two duplicate diagonals.
Join the square, planar to green plane.
Divide square side of 6 by 2 PI, for cylinder radius. Flow grid with green baseplane onto cylinder. Done
The two flat spirals used a baseline line, and a circle. MoI froze up (30 seconds) trying to move the magenta one, (took 30 seconds to cancel move.)
The file save worked, but the file does not appear in the MoI open list. (The magenta one is very large, 1,778 kb.)
EDITED: 10 Aug 2013 by BEMFARMER
5727.5
thank you people so much....
i will try these tehniques asap (tonight)...
Nec
5727.6 In reply to 5727.5
Hi Nec;
Another technique will be to use Helix. here the steps;
-draw a helix curve and set the turn to 1
-use Array circular to array the helix curve around the circle
-Select all the curves and mirror.
-Sharif
Show messages: All  1-2  3-6
