Does this yet exist...
... for curves or lines (and for conics) ?
for lines that will be a polygon passing by the points
And from a polygon ?
LineWeb needs lines or curves at start
EDITED: 18 Feb 2013 by PILOU
5722.2 In reply to 5722.1
Hi Pilou, no there isn't anything currently in place for that, by group selection, you would need to just draw a curve and snap on to those points and that should give you that desired result.
It's not really all that easy to automatically calculate ordered results from initially unorganized points like that, it looks like you may want what is called the "convex hull" of the points in that particular case there.
You may be able to find some utility programs to process the points here: http://www.qhull.org/ I think there's a command line program there that is able to process lists of points and output the convex hull or other kinds of results.
5722.3 In reply to 5722.2
Seems not a very friendly program :)
5722.4 In reply to 5722.3
Hi Pilou, yes but if that's the kind of processing that you need to do I think it has that stuff in it.
5722.5 In reply to 5722.4
OK I will see that
Seems there is an adaption in Sketchup :)
Minute 0.32
Qhull second post
http://sketchucation.com/forums/viewtopic.php?f=323&t=19040
and points in volume: fill construction points
http://sketchup-onigiri.jimdo.com/plugin-other/
I even use it in the past :)
And i can make that ;)
5722.6
5722.7 In reply to 5722.6
