RingCircle
All  1  2-7
5720.2 In reply to 5720.1
Hi Mike check out here for an updated version which will work with v3:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4933.2
5720.3 In reply to 5720.2
Michael,
Thanks for the reference. I still get the same error with this script, however, after I dimiss the messagebox it does run. Although I don't think it is running correctly in that next to the Size label are all of the dropdowns for each country. I'm guessing I'm only supposed to see the one selected.
Mike
5720.4 In reply to 5720.3
Hi Mike, could you please attach the one that you're having problems with so I can take a look at it?
Are you sure you got the updated version and not the older one?
The updated ones in those links above are supposed to solve that problem of the various dropdowns not getting hidden properly.
5720.5 In reply to 5720.4
Sure. Here you go.
5720.6 In reply to 5720.5
Hi Mike, you've got the old version there, you need the updated RingCircle2.htm file which is attached to this particular message here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4441.11
You may have downloaded the one that Colin attached directly above that message - that one is the old version.
I'll also attach the updated one here, if you use this version you should be working ok in v3.
5720.7 In reply to 5720.6
Perfect! Thank you for your help.
Show messages: All  1  2-7
