fbx out
All  1-7  8-17
5709.8 In reply to 5709.7
Keyshot version 4 is due to be released on valentine's day ... If you purchase before then you will get a free upgrade to v4. I love Keyshot, it's fast and easy, but its materials editor is somewhat restrictive, not seen the v4 one but v3 is definitely a pain at times. Also KS supports step files and it works perfectly with what MoI exports out ... Named objects come in as named layers and the style setting comes in as the name given plus rgb colour code. KS does offer animation sets, and if you go the whole hog you will be spending close to the same cost as Maya but just for a render engine ... But oh boy it's a good render engine.
I use Keyshot, so you can hunt through my posts to see the quality of the renders, you may not like my style of rendering, but if you can see past that, you'll see the render engines accuracy, also all the posts i have done here and in the gallery have all been done with the live render engine and are just screenshots and not the full blown renderer
If you don't need animation then you will be close to the expense of Maxwell render.
Hope that helps ...
Martin Spencer-Ford
@Burr
Lumion is the more easy and funny Prog that I have seen!
Absoluty crazy and a "game boy" UI !
Ocean, snow, wind, clouds, terrain creator as like Zbrush, pets, personnages, vegetations, still renderings, animations etc...astonished
You win a factor 7 for architectural Projects rendering against other progs !!!
The only problem is the price! Hoppefuly a free version exists for Hobbyst ;)
5709.10 In reply to 5709.7
""""""""""Oh actually I forgot last night that Luxion """""""""""
Yeah, Luxion is Keyshot. I have an older version of keyshot and simlab uses a luxion render engine.
The software i was refering to is "Lumion" and is more aimed at architectural visualization.
They have taken a different approach as it's more like a "game engine" that can pump out higher quality. Very fast and easy setups, animating and good quality animated objects.
Not a full blown animation package with power in materials and textures and finite controls.
What becomes appealing for me with this are the "realtime presentation" abilities it will provide.
I'll let you know if/when i get it and show you some stuff with it. I have a job pending that I will use it for.
EDITED: 10 Feb 2013 by BURRMAN
5709.11 In reply to 5709.9
"""""The only problem is the price! Hoppefuly a free version exists for Hobbyst """"""""""
Hey Frenchy,
Yeah, you turned me on to Lumion. Yes, the price is not cheap, but I will try to punch the price into a job I'm doing, and then I'll have it.
They DO have a free version, not for commercial use. It adds a watermark, and also is limiting in the amount of materials you can apply, and so forth. It's good enough to evaluate it, which is what I'm working right now, to be sure I can do what i want. The "other" downside for me, is it likes "gaming cards" like the new GTX cards. My current system is quadro based. I'll need to punch out a new Game rig to use it well also, which adds 3-4 K, but i have a few other apps that like those also and it seems to be more the "wave" with alot of stuff.
5709.12 In reply to 5709.10
Hi Burr,
Oops, I got my wires crossed there with Luxion/Lumion . I am not familiar with Lumion at all so it would be cool to hear how it works for you if you do end up digging into it.
5709.13 In reply to 5709.12
Dont forget Luxology, Lux Render, and Goldy Lux! :o
5709.14 In reply to 5709.13
What about Artlantis Studio if you're into architectural rendering http://www.artlantis.com/index.php?page=products/studio/index
5709.15
Hello Dr.Burr
if you are interested in real-time visualization,especially in stills, here is a new tip:
RandomControl,house of ARION and FRYRENDER(no more released) will release a LIVE plug-in for Rhino 5 !!!
what means this:inside Rhino you can have a realtime preview with one of best unbiased renderers quality
set UV's,materials,lights and everything else in Rhino than convert or apply Arion materials,so you can launch the render,or better..a real-time digital photo..
Arion use all cpu's+gpu's(nvidia)at same time or,if you want,you can choose which device use to render(if gpu or cpu)
If you buy Lumion base =1500 $ approx. that is same price buying both Rhino+Arion live
mantain your"old" quadro for navigation and UI display, and add a new one like a Gygabite geforce 660 ti 3Gb videomemory for computation(Arion ask you which graphic card you want to use)
so...1500+300( geforce 660)=1800$ approx
this new could be useful also for all Rhino users here
cool hat that one in the gallery !
M
5709.16 In reply to 5709.15
FYI: I believe that Octane is also developing a real-time plugin as well.
5709.17 In reply to 5709.16
Octane It's now also a "stand alone" ;) 199 € or 265 $
The new version is just released!
Import of Wavefront OBJ format with parameters and material import
Import supplied vertex normals or calculate them via supplied smooth groups
http://render.otoy.com/features.php
Show messages: All  1-7  8-17
