Peopeller blade
 1-6  7-26  27-29
5700.7 In reply to 5700.6
I tried again to upload but I don't see it.
5700.8
Maybe all I really need from you guys is, do you think Moi3D is the right program for my propeller blade? Or does anyone know of a better one?
5700.9 In reply to 5700.7
Hi AirAce,
You don't see what exactly? Do you see the "Attachment" button but when you push it you don't see the pop-up? Does your web browser display any notification bubble like "Popup blocked, click here to allow" or anything similar to that?
If you are still having problems you can e-mail the image to me at moi@moi3d.com and I will then post it here.
5700.10 In reply to 5700.8
Hi AirAce,
It's possible to do it, but MoI is not specifically designed for just doing propellers, it's more of a general purpose modeling tool and propellers are pretty advanced and difficult shapes to create so it's not like you will be able to just instantly jump in and finish a difficult and advanced model like that by pushing a few buttons... You'll have to spend some time just getting familiar with how to build models in general and probably you'll need to start out with doing more simple things to begin with rather than trying a difficult shape as your starting project.
Here are a few previous discussion threads which you may want to check out though:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4144.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=1694.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=305.1
http://moi3d.com/forum/messages.php?webtag=MOI&msg=302.1#a302_1
http://moi3d.com/forum/index.php?webtag=MOI&msg=578.1
5700.11 In reply to 5700.8
Hi Kent, I've attached the PDF that you e-mailed to me here.
And in order to get those images into MoI as a background image you'll need to convert them to a bitmap file format like PNG or JPEG format, then you'll be able to bring them in as a background image using the View > Image command so that you can trace over them.
I think the points for the stations could be imported using the ImportPointFile script. (?)
5700.14 In reply to 5700.13
Here is a txt file of the Station 18 points, tab delimited, created by entering the x,y,z points in notepad++, and using ImportPointFile script to load them into MoI.
Shown are the points, imported once, and secondly entering the points as through points.
Note that the second set of Y coordinates had to be entered in reverse order.
EDITED: 19 Feb 2014 by BEMFARMER
5700.15 In reply to 5700.14
Hi AirAce,
Just a brief comment on your question of whether or not this is the program for you to use to design your propellers:
I can't answer that - guess it depends on your time & what may be the most intuitive workflow for you - but about ½ a year ago I was searching for a 3D modeling program to do the modeling I would like to do. I searched and tried some 3D programs including Modo, Autodesk 123D, and a couple more but chose Moi3D because to me it was quite intuitive and straightforward to use. Within a few hours of learning I was actually able to make some models that shape-wise were quite realistic (I opted out of photorealism when not choosing Modo) and which could be 3D printed (my need so far) due to the selection of export file formats.
Since then I've put more time into learning the program and although there are still pitfalls and aspects I do not (yet?) know about I am reasonably confident that I can get quite far in my modeling - and then learn what I need to know if there's something I can't make work.
Also - when choosing the program - the price was within my reach and when I had some challenges with the models I was doing (with the trial version) I received very good help here in the forums.
So - those were some of my criteria for selecting Moi3D. Good luck in selecting your way in modeling :-)
Best regards,
Jesper
5700.16 In reply to 5700.15
Thanks Jasper, good input. I am pretty sure this program will do the job. A propeller blade does not have any "insode" 3d surfaces that a machine would have to deal with.
I have been disappointed with some of the othe CAD programs I've bought. I have used AutoCAD, FreeCAD and I now have Alibre. Alibre may well do the job. But it is so painful to try to learn it.
The CAD program that I like best of all is E-machineshop. Too bad you can't buy it and use it at home. You have to order your parts from them, that is, the company that furnishes the CAD program.
5700.17 In reply to 5700.14
Soon as I learn how to do this I think I will be making some real progress.
Thanks much.
5700.18
You will be able to create the propeller blade Ok with MoI's tools by lofting between cross sections, using network or doing a two rail sweep. Where you will run into problems is creating the end tip of the propeller blade. I don't think you'll find an effective way to do that with MoI's tools and making it blend into the rest of propeller surface seamlessly.
~Kevin~
5700.19 In reply to 5700.18
It will certainly make whatever you can draw!
5700.20 In reply to 5700.14
Did you just type in those numbers in notepad? And then just import that into the CAD program?
5700.21 In reply to 5700.18
Please excuse my ignorance for not being a computer guru.
Can you tell me how to use a network or a two rail sweep.
Both ends of the propeller blade will be hand finished after removing it from the router.
5700.22 In reply to 5700.20
"?Did you just type in those numbers in notepad? And then just import that into the CAD program?"
Yes, notepad would work. Actually used free notepad++ program. Used tabs (as delimiters) between numbers, enter at end of lines. Changed the order for the other Y column. Other delimiters can be used. For the curves, selected Close Ends.
Yes, just import with the tab delimiter option, select points or controlpoint curve or interpcurve point curve option.
EDITED: 9 Feb 2013 by BEMFARMER
5700.23 In reply to 5700.21
Hi Kent, there's some information on both Network and Sweep in the help file - check out the reference section of the help file which has an entry for every command, often with some screenshot illustrations.
Here's the entry for Network:
http://moi3d.com/2.0/docs/moi_command_reference7.htm#network
And here's the one for Sweep:
Also there's some more discussion on what kind of curve structure is required for Network here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4384.4
http://moi3d.com/forum/index.php?webtag=MOI&msg=1778.6
5700.24 In reply to 5700.14
Bemfarmer, do you do consulting work?
5700.25 In reply to 5700.15
Hi Jasper,
I have been able to do 3D modeling after bothering Michael a few times. And Bemfarmer did a good job of entering the coordinates for one station. I am now on the leading edge of the learning curve on exactly how to do that. I think that once I can do what he did with the numbers I will be able to put it all together.
Thanks for your input. Much appreciated.
5700.26 In reply to 5700.24
Sorry, no consulting work.
Show messages:  1-6  7-26  27-29
