no solid
5690.1
Hi to all, I'm not able to create a unic solid from these two surface. Why?
EDITED: 4 Feb 2013 by FILIPPOL
5690.2 In reply to 5690.1
There is a very small, diamond shaped hole, at the tip of the point of the smaller srf.
Size: 50.8 KB, Downloaded: 37 times, Dimensions: 682x464px
5690.3 In reply to 5690.2
Thank you!
I try to solve it now.
Do You see it with a script or with zoom step by step?
_________________________
That's a brilliant day to design!
5690.4 In reply to 5690.1
Hi FiL, it's pretty helpful to set up a shortcut key for the N key to select "Naked" (unjoined) edges. That really helps to locate open areas like this, see here for more info:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4869.5
5690.5 In reply to 5690.4
I've tried it. It works very well. Thank you very much.
