Save larger image to clipboard with print screen
All  1-3  4-7
5686.4 In reply to 5686.2
Script seems to be working fine now, tried to paste in another program and all is well. I tried pasting into gimp 64 bit at first, so maybe the problem is gimp associated.
Again, Many Thanks for your assistance!.
5686.5 In reply to 5686.4
Hi
I am using this script:
script: /* Custom screenshot */ var prev_background = moi.view.viewportBackgroundColor; moi.view.viewportBackgroundColor = 0xFFFFFF; moi.view.lineWidth = 1; moi.grid.display = false; moi.grid.showXYAxes = false; moi.view.showAxisIcon = false; moi.view.meshAngle = 3; moi.ui.getActiveViewport().renderToClipboard( 4000, 2500 ); moi.view.lineWidth = 1; moi.grid.display = true; moi.grid.showXYAxes = true; moi.view.showAxisIcon = true; moi.view.meshAngle = 8; moi.view.viewportBackgroundColor = prev_background;
But, it only take a screenshot of one view. Is it possible to take a screenshot of the four views all together? With the same settings, and, if possible, (i'm asking a lot!) with an automatic "zoom all" of each view.
Thank you
Moujiik
5686.6 In reply to 5686.5
Hi Moujiik,
Sorry no, that mechanism is only set up to generate an image of one view to the clipboard, there isn't currently any way for it to make multiple views in a single image.
You could use a more regular screen capture to do that, push "Print screen" and that will capture an image of the desktop to the clipboard. That will have all views like you want but it will be at your regular screen resolution.
Either that or you would need to run the other single screen method 4 times to generate 4 different images and then combine those together in an image processing program.
5686.7 In reply to 5686.6
OK. Thank you Michael. Those screenshots work well for presentation. Simple and effective. I'll make those 4 views "by hand".
Moujiik
Show messages: All  1-3  4-7
