domed roof tiles on
5683.1
Hi all,
I try to realize a domed roof with tiles like this photo
What is the best method for tiles conform to the shape of the roof while being one of the others?
Thank you in advance
5683.2 In reply to 5683.1
Maybe with the Flow function
Of course you must put the exact number of tiles (not like me where I take a square number of tiles)
and with an offset by line of course ;)
So draw the project from view top and project them
Another solution will be to use the Array Circular line by line
And decrease number of tiles line after line
Else use a texture of tiles in your favorite render if you want not draw each tiles!
EDITED: 31 Jan 2013 by PILOU
5683.3 In reply to 5683.2
Merci Pilou pour cette piste que j'ai tenté mais sans succés ! car j e n'arrives pas à avoir les tuiles plaqué correctement sur le dome et surtout quelles se reposent les unes sur les autres!
j'ai dupliqué une tuile sur une courbe ensuite je pivote la tuile pour quelle soit palcé nickel ensuite j'applique une trame circulaire
ca fonction mais c'est assez long à mettre en oeuvre mais ca marche !
Encore merci du coup de main
<img src="get_attachment.php?webtag=MOI&hash=362d40694082c16e841e26be750e9eb6&filename=Capture d’écran 2013-01-30
EDITED: 30 Jan 2013 by HDRI3D
Size: 205.9 KB, Downloaded: 42 times, Dimensions: 1351x959px
5683.4 In reply to 5683.1
I think there is a script for jewel array or array gem command, so you can array the tiles over the dome surface on each correct line.
i did a basic search but couldn't find it, but there must be somewhere here in the forum.
**Edit: founded, look here for ArrayGem command: http://moi3d.com/2.0/docs/moi_command_reference10.htm
just set up a shortcut key on your options
Luis G.
EDITED: 30 Jan 2013 by LGRIJALVA
Are the tiles getting smaller as they go up?
The tiles seem to line up vertically.
It looks fibonacci-ish and paracloud gem-ish?
5683.6 In reply to 5683.5
ParaCloud good idea ! :-)
thank you
5683.7 In reply to 5683.4
thank
5683.8 In reply to 5683.7
Any chance to view the process of Paracloud for that?
