Extrude again
All  1-11  12-16
5673.12 In reply to 5673.11
Hi Pilou, do you have a tighter than default angle set for Options > View > Meshing parameters?
The default for that value is 10 degrees, which already generates pretty dense display meshes. If you have it set to an angle less than that, it will cause really very dense display meshes to be created which will consume a lot of memory especially on chaotic surfaces like these.
Especially if you have an old computer you probably will not want to set it to less than 10 degrees.
5673.13 In reply to 5673.12
Yep that was that!
Now I put 50 and it's instantaneous even for the 1.5 mega file!
Cool !:) here Biz
5673.15 In reply to 5673.14
very interesting, thanks for sharing, and not only Architects, but object designers too
Luis G.
5673.16 In reply to 5673.7
With this code you can start a new version of Moi for Post-modernists. They'll jump all over it :)
Show messages: All  1-11  12-16
