Selction of same size elements
5669.1
Is there a way of creating a script, that I can run via a shortcut, that selects other curves of the same dimensions, length, diameter etc? This is similar to Spaceclaim's selection tab where you can choose a range of selection options to add to your active selections.
This is very useful when creating patterns with curves to later use as boolean cutters.
5669.2 In reply to 5669.1
Hi Matt, I don't think that it's possible to make a script to do that right now, because some of those attributes like diameter or length are not currently exposed to the scripting interface. The only thing that I think a script can get at right now like that would be the overall bounding box of the object.
