Moi.ini
All  1-2  3-4
5665.3 In reply to 5665.2
Oh yes I think it's because I had two windows !
Will try it again tomorrow at work :)
Thanks for the answer Marc, I wouldn't have noticed that behavior myself.
shapenoid.com stojan-voumard.com
5665.4 In reply to 5665.3
Hi DesuDeus, yeah the way it works is each window represents a separate "instance" of MoI and each one writes out its current settings to moi.ini when it closes. If you have more than one window open make sure to close the other ones before you edit the .ini file.
I'd like to change how this works in the future so that an instance will only write out a particular setting if it had actually changed rather than just always writing out all current settings.
Show messages: All  1-2  3-4
