Moi.ini
5665.1
Hi there,
I replaced my MoI ini with an old one containing all my shortcuts, everything is fine but...
I modified a few shortcuts then closed MoI and re-opened it the next day, the new shortcuts were gone.
It's kinda like if my MoI.ini was read-only :(
Is there any good way to keep shortcuts between updates without messing with everything else ? Also settings between versions (view, line aliasing etc...)
shapenoid.com stojan-voumard.com
5665.2
Hi, maybe there was another Moi window and you closed it after the one you made the changes?
I think the last one closed rewrites the ini file.
Marc
5665.3 In reply to 5665.2
Oh yes I think it's because I had two windows !
Will try it again tomorrow at work :)
Thanks for the answer Marc, I wouldn't have noticed that behavior myself.
5665.4 In reply to 5665.3
Hi DesuDeus, yeah the way it works is each window represents a separate "instance" of MoI and each one writes out its current settings to moi.ini when it closes. If you have more than one window open make sure to close the other ones before you edit the .ini file.
I'd like to change how this works in the future so that an instance will only write out a particular setting if it had actually changed rather than just always writing out all current settings.
