Network doesn't work for me
All  1-6  7-11
5651.7 In reply to 5651.5
Network do not work this way only the first figure.
To make this kint of thing it will be better to use sweep. Select arcs and then sweep and select rails - 2 curves on the ground. (second figure)
5651.8 In reply to 5651.6
Hi Stefan,
Can you confirm what you trimmed and then what you selected to make it work? The only way I can make it work is to select only four pieces, and ignore the front and rear curves.
Thanks!
Hi Reuben,
as you can see in both pictures, i selected all the lines at once (see the trimming points) and applied the trim command. As second step i started with each region separately for the Network Command. Hope my explanation makes sense.
EDITED: 30 Oct 2016 by STEFAN
5651.10 In reply to 5651.1
Hi Reuben, yeah in order for Network to be able to work, it needs to organize the curves into 2 separate crossing sets, and those sets should form a grid shape similar to how longitude and latitude lines on a globe can make a grid on a flat map. If you have arrangements that can not be "unwrapped" in to a regular flat grid then it won't work.
There's some more discussion on the type of arrangement that Network needs in some of these previous threads:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4384.4
http://moi3d.com/forum/index.php?webtag=MOI&msg=1778.6
5651.11
And Reuben, the reason why the circle with the four spoke curves touching at the middle works is because it is in fact making a 'grid' Network. It's just wrapped around a tight axis.
Show messages: All  1-6  7-11
