Modelling the DeHavilland Canada Caribou.
All  1-9  10-14
5638.10 In reply to 5638.9
Hi John, you've gotten your objects doubled up - the things that look like a surface but report as a solid are in fact 2 surfaces exactly stacked on top of each other with their edges glued to each other, making a kind of infinitely thin invalid solid.
The indicator will read as "Solid" if you've got a shape that has all edges joined to one another - it would take a lot of extra time to try and analyze the shape to look for invalid situations like you've got here, so that readout does not try to do anything fancy like that, if it sees all edges are joined it will say "solid" there.
So in order to fix this you need to select each piece that says that, and run Edit > Separate on it, and then click on it at which point one of the doubled pieces will be selected, then delete to get rid of the doubled ones. In fact you will probably want to continue deleting until you see that there is nothing left and then undo one step to recover the last one, just in case you have got actually more than 2 stacked up on the same spot.
This kind of thing can happen if you duplicate objects directly on top of one another and then use Join on them.
5638.11 In reply to 5638.9
Just that not verey easy to use the gride with these proportions ;)
5638.12 In reply to 5638.10
Many thanks Michael. Blindingly obvious once you point it out !
My original thought was, if I modelled this aircraft full size, then I could easily scale it down prior to building a real model.
However, I have found it difficult to pick existing points and edges accurately.
Do you have any thoughts on the matter ?
John
5638.13
Always model full size.
5638.14 In reply to 5638.12
Hi John, it can help if you use a unit system that is more of a match to the full size of your object. Like maybe use meters as the unit system rather than inches.
Show messages: All  1-9  10-14
