Advantages of v3 for "meshing users"?
 1-15  16-27
5637.16 In reply to 5637.15
Sounds good, we could try it. :)
Visualisation for Designer and Architects | http://www.simulacrum.de
5637.17 In reply to 5637.16
Hi Micha, I've attached here a test for you to try to see if a setting for OBJ export for "Write styles as groups" will help.
For this test, in Rhino set the mode for "Import OBJ groups as: Layers" and also set "Map OBJ Y to Rhino Z". Hopefully that should then bring in the mesh onto the original object layers as you want. You should be able to open the original 3DM file, and then do an Import of the OBJ file with those settings and then the import should bring the meshes into the original layers.
The first one is a simple test, the second one obj_test2 tests using spaces in the group names, but as discussed earlier by the actual OBJ file specification any spaces in the group name is supposed to be mean that multiple separate groups are active (spaces are meant to separate multiple names) rather than it being one single group name so that may not work. If that does not work you would need to either ask McNeel to have an additional option to control that group name reading behavior, or have a Rhino script replace all spaces in layer names with some other character like an underscore before doing any of this processing.
5637.18
I had to test those with R5 WIP on the OSX platform ...
Test1: I get Blue red green layer names with black shapes (cuboids) .... Is that how it should be. The 3DM has the colours to suite the names
Test2: I get "layer", "with", "Spaces" along with default and 2,3,1,4 all on their own layers with no colour assignment
Hope it helps
Martin Spencer-Ford
5637.19 In reply to 5637.18
Hi Martin, thanks for testing it!
If you use the "Open" command directly on the OBJ file then yup that's what you are supposed to get. In order to maintain the layer colors you would want to do things slightly differently - use "Open" on the 3DM file, this will read the original layers in including their colors, and then use "Import" instead of "Open" to bring in the OBJ file, that should then bring in the meshes and map them to the original layers.
That means that spaces won't work, which is not really unexpected as discussed above.
5637.20 In reply to 5637.19
Hi Michael, the reason R5 on OSX won't import properly ... or i think it's the reason why, is when I import it opens a new session, so using your steps above is futile here;
Just to make sure i am not totally dumb, here's what I did
step1 ... Open the 3dm with R5
step2 ... Attempt to import OBJ file (R5 says sure, i will import that but here have a new workspace to play with)
However just for argument sake ...
step3 ... Select all cubes that are coloured black in new workspace created by the imported OBJ contents, select copy, and then paste those cuboids into the original session and the cuboids come in with their colours assigned correctly and are approx. 20% the size of the original cuboids in the 3DM file
Martin Spencer-Ford
5637.21
I tested in with R5 64 here and it's like you wrote, the layer names are splitted. I will ask the Rhino team for a way to keep the names.
Micha
5637.22 In reply to 5637.20
Hi Martin, hmmm maybe it's called something different on the Mac version - on the regular Windows Rhino version "Import" means the same thing as it does in MoI, meaning to bring in the contents of the file you pick and add them into the current model without removing any of the current stuff and not starting a new workspace.
Surely there must be some way to do that with the Mac Rhino version, is it possible that it's called "Merge" or "Combine" or something slightly different?
5637.23 In reply to 5637.21
Hi Micha,
So other than this "names with spaces" issue, does it look like that will do what you need?
Someone on the Rhino newsgroup could probably write a little script that would convert layer names to switch spaces in them to underscores.
5637.24 In reply to 5637.22
Nahhh, no merge or combine, there is an insert but that wants to work with blocks. If it is of any consolation the very buggy R5 WIP also opens a new workspace on "importing" another 3DM file, it's probably an issue with permissions, but it was installed with their own installer but that don't mean much with nix based systems, I will download the latest build later and see if it's fixed in that, if not i will run the fix permissions tool and see if R5 plays any better there-after.
Martin Spencer-Ford
** Updated **
Ok just installed the latest build of R5 WIP, no difference, did repair some permissions but nothing directly to do with the software just installed, and still no difference, even from the initial starting workspace, select open, and you get a new instance of R5 ... Ah well, never mind, still got my MoI!!
EDITED: 15 Jan 2013 by TPWUK
5637.25 In reply to 5637.23
"So other than this "names with spaces" issue, does it look like that will do what you need?
Someone on the Rhino newsgroup could probably write a little script that would convert layer names to switch spaces in them to underscores."
Yes, this could be a solution. Is there a chance to get the "use style names" option for v2 too?
5637.26 In reply to 5637.25
Hi Micha, ok I've added that in for the next v3 beta.
It will be a new setting in moi.ini under [OBJ Import], called:
[OBJ Export]
WriteStylesAsGroups=n
You will be able to change this to say WriteStylesAsGroups=y and then you will be able to output the kind of files that I posted earlier.
By default spaces in the style name will get converted to underscores. There is another setting you can change to enable writing spaces AllowSpacesInObjectNames=y but you will need support for that on the Rhino side before that will work properly. Until then you would probably want to have some script in Rhino that will replace all spaces in layer names with underscores so that does not cause a problem with the names changing.
Sorry no, v2 is not really under active development now, v3 is where I'm adding new things so that's where this new feature will be in.
5637.27 In reply to 5637.26
Thank you. :)
Show messages:  1-15  16-27
