Problem Trimming Knurl
 1-18  19-23
5631.19 In reply to 5631.14
I've attached here (in the .zip file) a 3DM with that one more difficult cutting surface just moved up slightly so that it does not have any area where the knurl edges skim right along the surface, now it should trim without any extra messing around needed:
But depending on what you want to do with these pieces it seems like you may want to have a 2D cutting curve instead, the 3D cutting surface is banking around and adds a kind of extra angle to the cut up result, that may make it more difficult to get the results connected up to other pieces - a 2D cut will be more uniform and simple in its result.
You could get the one in your original position to work but it will probably involve a fair amount of clean up work, you'd need to generate the intersection curves and then go in and clean up the messy parts and then once you've got a good curve with no overlapping/backtracking type pieces in it use it as the cutting object.
5631.20 In reply to 5631.19
You're right. That's pretty messy.
Would it do the job if I just 2D cut a plain extruded tube surface and flowed the knurl pattern onto the remaining pieces?
In any case, thank you all for your contributions.
5631.21 In reply to 5631.13
"Was this created from using Flow? There probably needs to be a tune-up to Flow to join these things up when opposite sides of the original object end up touching one another in the flow result."
Yes Please :) when using flow for rings, I normally have to take the STL output to netfabb to join up the area where the object ends touch :)
5631.22 In reply to 5631.20
No, that wouldn't really make any difference - Flow works on a full "underlying surface" - if you cut out a hole in the middle of something it does not make any difference as far as how Flow will be used on it.
Does the model that I attached above that will trim work ok for you?
5631.23 In reply to 5631.22
Sorry I didn't get back to you. I was dealing with a medical situation that arose and was nowhere near my computer for most of the week.
Yes, your model did the trick, although it wasn't immediately apparent. I had to cut it in half diagonally to better allow my computer to crunch the numbers.
Ended up making a solid tube out of the knurled section. Cut that in half diagonally. Then I used my sweeping curves to cut out the shapes and isect to make cutouts from the sweeping curves. Then I joined everything to make solids again.
Here's the result:
As you might be able to tell, it's the rubberized grip on Count Dooku's lightsaber. I got a replica for Christmas and immediately set out to model it. It's excellent practice and compliments my Luke and Obi-Wan virtual models.
Thank you so much for your help and insight.
Show messages:  1-18  19-23
