Squircle script
 1-7  8-27  28-44
5616.8 In reply to 5616.7
Hi scott, yup that's correct - it's the actual name of the file itself (without any extensions on the end of it like .js or .htm) that is used as the command name.
Here is an upgrade of the squircle script, "SquircleZ2D," for placing half a squircle between two picked points.
The squircle is drawn in the z axis direction, but may have some portion with an x or y component.
Added in a slider for the shape. The slider does not continously update like the binding "Bulge" one in MoI blend factory, or maybe I've left something out.
(Another version has just numeric entry for the shape value.)
It is required that for the two points, either the x values must not be equal, or that the y values must not be equal. There is some buggy-ness in 3D view,
in the event that respectively, the x values and the y values are each very nearly equal.
I anticipate using the script to place squircles on two guide rails, in Top view, for a sweep.
Checking the repeat box permits many curves to be placed, quickly.
Did some testing with a cube edge skeleton, in 3D view.
Negative heights are allowed.
Used cross product to create an orthogonal axis for a new frame.
Re-used lots of code from many other scripts.
Did not provide for foreign languages "substitution" of name labels..."
Now to go back to the extremely difficult Levenberg-Marquardt solver.
5616.10 In reply to 5616.9
About the algorithm
it's more easy say calculate in front view the Squircilcle between distance 2 points given, then rotate this result in the 3D Space
or calculate directly between 2 points in the 3Dspace ?
5616.11 In reply to 5616.10
peut etre?
Edit: Will try something else for the newport shell. The edge just needs to be swept or flowed or networked along 3D curve(s)...
EDITED: 7 Mar 2013 by BEMFARMER
Here is a different version of a squircle, which is not a superellipse.
_squircleFG script, by Brian McMillin 2/11/2022.
This script produces the Fernandez-Guasti squircle, which is an intermediate shape between the circle and the square.
https://arxiv.org/ftp/arxiv/papers/1604/1604.02174.pdf
tau, Є [0,1], is the linearized squareness parameter.
Click on "Click for 50%", for 50% squareness.
Radius, (radVal), = radius of circle = halfwidth of square.
Parametric value rho is the varying polar radius.
The "curve factory" is used, as it has a much nicer corner, for tau at or near 1.0, than the corner of the "interpcurve factory", which is wiggly. Note that numpoints should be an even number, for a slightly less rounded corner.
For tau = 1, (maximum squareness), the corner is still slightly rounded, and "show points" shows the control points for the curve. If numpoints is even, there is a control point at the corner, but it is NOT a "corner" control point. MoI cannot, currently, directly convert this point to a "corner" control point. The point can be manually deleted, (or odd numpoints used), and a "corner control point" inserted at the midpoint of the dotted line between the two remaining points nearby, and the new "corner" control point dragged to the corner of the square, to make the corner of the square a 90 degree corner.
Division by zero would occur at theta = nPI/2, so these 5 cases are handled individually, which is possible because the limits there goes to +/- radval.
Division by zero would also occur at tau = 0, so the tau slider has a min value of 0.000001. BUG?, In the Squareness menu, if tau is set to zero, the curve is blanked. Checking if tau === 0, and if sqfactor === 0, and setting their values to 0.000001 does NOT prevent entry of 0 into the tau menu causing blanking the curve. sinval === 0 checkdid not help either.
EDITED: 13 Feb 2022 by BEMFARMER
_squircularCyl script, (non-uniform), by Brian McMillin 2/13/2022.
This script produces a square to round cylinder, as per page 27 of the paper by Fong for the Fernandez-Guasti squircle, which is an intermediate shape between the circle and the square:
(For a uniform squircular cylinder, just extrude one squircle.)
loft suggested.
extruding the top and bottom squircles, and blending their two edges produces a similar, but different shape.
EDITED: 14 Feb 2022 by BEMFARMER
SquircularConeNOT.
Call it serendipity. This script was supposed to produce a square to round cone, as per page 27 of the paper by Fong, but something unknown went wrong. After a loft, the 3D shape was so cute, I decided to keep the script. The only change was to multiply the radval by tau. (repetitively, by mistaken code.)
5616.15 In reply to 5616.14
Thanks again Brian!
In the SquircleNOT loft, I added a point to end it.
Remember the point included at the end of loft allows the loft to end in a point...
Just 2Cents! But Thanks again for all the contributions you have made!
Burr
5616.16 In reply to 5616.14
Here is a non-uniform SquircularCone.
radval = radiusMax * tau. (rather than repeatedly multiplying radval by tau.)
This cone looks good also.
Setting z=0 puts all the squircles in a plane.
Undone, is a squircular cone with constant tau squareness in each cone, with tau varying between cones.
Maybe tomorrow.
5616.17 In reply to 5616.15
Thank you Burr.
Adding a point looks good.
Object looks like some building or tower roof...
5616.18 In reply to 5616.17
Is this something that you would consider making into a node for the Node editor? ( Please say yes, because it I would also like to make it into a node, but you know far more as to how it works.)
Wayne
5616.19 In reply to 5616.18
Hi Wayne,
Feel free to make the squircle variations into a node, or nodes.
I would, but am not so good a programmer, and winter light duty time will soon be gone.
And I have not finished the other script that has occupied the past 2 months.
This morning, I had a few ideas regarding a few, mostly "cone", combinations.
Basically to separate radius value from tau squareness.
Have radius value either fixed, or linearly variable, or geometrically variable.
Have tau either fixed, or variable.
(Modes?)
5616.20 In reply to 5616.18
Here is a DRAFT version of a squircle node.
Add on an Output node, and the script works. Still does not like a sqfactor of 0.0.
Place the two files in the extension directory of nodeeditor.
Alternatively, the squirclefn file can be placed in the lib directory. It just contains two functions.
Still wondering if the two functions could be put in the squircle.js node file.
More testing to do...
See post 38 for "final" version.
EDITED: 20 Feb 2022 by BEMFARMER
5616.21
5616.22 In reply to 5616.20
Brian,
This is a good start. I was working on a different version, but still learning the function and how they go together. After following many of Max's node code, yes, the functions can be on the main code. Making it a multi-Process function would be a good test for speed.
Wayne
EDITED: 17 Feb 2022 by WAYNEHILL5202
5616.23 In reply to 5616.22
Thank you Wayne.
I made a few changes to the node today.
Placed the two helper functions near the top of the .js file.
They are called a little bit different that the previous squirclefn file.
The squirclefn file was not really necessary, but could have been place in either the extension folder, or the lib folder.
Have not posted the changes yet...
EDITED: 17 Feb 2022 by BEMFARMER
This new node is based upon translated mathematica code.
arcLoop.js is a node which produces a planar closed curve made up of arcs and a line for a flat side. It can display circle, ellipse, "lens", and 4 sided "diamond" quad lens shape. It can also have one flat side. It may be considered a cross section in a forthcoming script. Place arcLoop.js in the nodeeditor expansion directory.
The arcLoopNodePgm.nod may be placed with other .nod files.
The helper function is placed near the top of the .js file, not in a separate functions file.
This is NOT a squircle node.
Do not claim to understand the math.
Have not been able to locate such loops with google searches.
5616.25 In reply to 5616.24
Using MoI to investigate the arcLoop shows the affect of the parameters.
For "aspect" of 1:
Radial and Transverse = 0 results in a circle plotted as a curve. It is not a regular simple nurbs circle. (The loop becomes an ellipse for aspect !=1)
Radial != 0 alone causes a lens of the intersection of two equal circles.
Transverse !=0 alone causes a lens of the intersection of two equal circles, At 90 degrees.
The loop is that of two intersectiing circles. The rounded corners are just the natural rounding from limited numpoints plotting a curve with lots of points, which rounds the corners automatically, rather than a simple nurbs circle.
Both radial and transverse != 1 causes a diamond quad lens, with all 4 sides being circular arcs of many plotted points, with automatic corner rounding.
The loop approximates the intersection of 4 equal big circles.
For "aspect" != 1, the arcs are each a segment of an ellipse.
"Flat" tends to make a line flat area, for large enough flat value, on the right side.
radiusFil scales the loop. It does not "fillet" any corners.
radius also scales the loop.
5616.26
Updated node code to include sub functions and changed to a multi-Process node.
Will be making a version like the original MOI UI to create lofted cone objects.
Wayne
5616.27 In reply to 5616.26
Nice work Wayne.
With a quick look, it appears that sqfactor and tau are both being used. But this is OKAY (at first I thought that it was not okay).
In notepad++ Ctrl+h helps with replacing one name with another, for myself.
Looking forward to your lofted versions.
I like initial tau = 0.5, the halfway shape between circle and square.
But after seeing numpoints = 1, maybe multiprocess is better with initial tau of 1?
I dislike numpoints = 1 as default(???)
Changing colors seemed to be a problem? Seems to be a need to unlink output curve to get colors to change? Maybe this is normal general behavior?
EDITED: 19 Feb 2022 by BEMFARMER
Show messages:  1-7  8-27  28-44
