detect colisions or overlaping solids or faces?
All  1-4  5-7
5608.5 In reply to 5608.4
Hi mjs, if I understand what you are asking correctly - yes there is a tolerance involved when testing for surface/surface coincidence as well. But usually it helps with various mechanisms if overlapping areas are within a pretty tight tolerance, if they wiggle through each other by too much it can be detected as a complex intersection rather than a overlap/coincidence type situation.
5608.6
It is exactly what i was after. In Spaceclaim there is a command called Inteference (or something like that) that point and - if you want - fix it, but in Moi i just need those areas to be pointed out.
Thanks a lot.
Carlos
5608.7 In reply to 5608.5
Thanks. that is what I was after.
Show messages: All  1-4  5-7
