Hi mjs, if I understand what you are asking correctly - yes there is a tolerance involved when testing for surface/surface coincidence as well. But usually it helps with various mechanisms if overlapping areas are within a pretty tight tolerance, if they wiggle through each other by too much it can be detected as a complex intersection rather than a overlap/coincidence type situation.
