How make that ?
 1-18  19-38  39-58  59-75
5590.19 In reply to 5590.18
Thanks Martin - I think the blend surfaces may be missing in SAT format because they're probably specified as a "logical blend" where instead of storing the actual NURBS surface what is stored is just a kind of tag saying "make a blend between these edges" and then the receiving application needs to calculate the actual blend. You may be able to set some option at export time to stop that from happening and having it write out NURBS surface data for everything, possibly by specifying an older SAT file version (maybe ACIS v8 or v7 or something along those lines).
The main thing that I wanted to check was surface quality, and there are several problems with the blend surfaces generated by ViaCAD, with some ripples and bumps and lack of tangent continuity... It's difficult to see these problems in ViaCAD's display since it tends to use a pretty rough triangulation which tends to make it hard to really analyze the surface quality very well.
You can see some of these problems in these areas here (all following screenshots in MoI):
It's possible to get a really really clear image of every nuance of a surface in MoI by exporting to a polygon mesh format like OBJ format, and then cranking the mesh density up super high so that you can be sure that there are plenty of polygons being used in every nook and cranny of the surface, that will then show you the surface in super high definition. So for example I cranked the mesh export up to this level of density:
All those little tiny black lines are the outlines of little teeny-tiny polygons, this is how you can be sure that you're seeing a really good image of the surface without polygonal artifacts coming into play and obscuring things. With every polygon about the size of one pixel it basically eliminates any polygon shading blending artifacts. Then when turning off the edge display and and only showing the shaded result you can see this is the super clear view of that same surface:
There you can pretty easily see the problems near the boundary edges - there's a bunch of bumps and the patch surface does not meet up with the adjacent surfaces totally tangent, there's a sharp area where they meet, particular at the top and bottom juncture areas.
There are similar problems with every single one of your other examples, here are some screenshots:
I've also tried some various test cases in ViaCAD myself and seen these same kinds of problems too, so I thought I'd ask you for your file to see if your own examples were of good quality or had these problems.
This is kind of troubling in general because I've sometimes thought that maybe I should license the ACIS geometry kernel to improve filleting in MoI, but if this is the best quality that the n-sided patch mechanism in ACIS can deliver I'm not sure that it will really be that great, although I guess an argument can be made that it's better to have this than nothing... and also some kinds of usage purposes like if you're making an STL/3D printed result the size of the lumps are small enough that they're probably less than the size of the printer resolution itself and so probably don't matter for that case. It's not nice for high quality rendering though.
It kind of turns out that MoI's high quality surface display is almost something of a curse in this situation - just the regular display without doing the high density export generates enough triangles that you can see these surface defects during regular modeling, while other CAD programs have such a lower density triangulation that these defects get obscured and many people are just unaware that there's a problem until maybe they try to export something to a renderer and make it reflective and see that it looks bad in a close-up in the renderer...
I guess that possibly a good n-sided patch mechanism is rarer than what I had previously thought. Or maybe just all these cases are just too difficult on it to handle very well, although even just doing a setback corner on a box has problems. The file valise.3dm posted at the very first message of this whole thread has a whole bunch of lumps and bumps all over it...
EDITED: 8 Dec 2012 by MICHAEL GIBSON
5590.20 In reply to 5590.19
Here's a patch srface from rhino so you can turn on control points to see what it's doing. I still got a little "dip" in my tangent connections, but I think it was more of a poor choice for UV count to produce a good surface. I later tried 9x9, which was using the compound of 3 to get more equal. It "looked" like a better result. I would certainly have to study up on it to use it well.
5590.21 In reply to 5590.20
Hi Burr, yeah that's not all that bad, I think it may be G1 but even with your improved one there still seems to be a bit of a wiggly dip right near the boundary edges:
The other thing is that it doesn't work all that well to have a zillion parameters to adjust for these when they're happening as a part of filleting, because there may be a variety of different shaped corner junctures being used all in one single fillet operation and it would be pretty awkward to try and integrate some kind of corner patch parameter adjustment to every single fillet corner...
Would you guys let me make the MoI display look cruddier so that you won't be able to see these kinds of problems? ;)
5590.22 In reply to 5590.21
""""""""I think it may be G1 but even with your improved one there still seems to be a bit of a wiggly dip right near the boundary edges:"""""""""
Yeah, that seams to be from that "flip up" in the upper corners of the untrimmed surface created, and I wasnt quite sure which of the 8 something parameters were to control that! That surface was using a 30x30 UV setting, that I think allowed it to flex there. I didnt save the 9x9 to re-check it in MoI.
I guess thats why we wait so long for n-sided patch. It will be it's own complex area adding that dreaded extra UI.
Please dont degrade the display to fool me. I get that in a couple other apps already :o
5590.23
Hi all.
I haven't got much time to add to this today, other than to include a screen shot of the ViaCAD file I posted in the zip, and which has had part of the STEP file imported and superimposed on the right of the image.
The point being that there's a big difference in surface quality between the two, so I think ViaCAD must be messing up in some way when it exports to other file formats.
I'm not saying the original ViaCAD effort it perfect, just that it compounds whatever faults are there when it does an export.
Martin (2).
Size: 215.8 KB, Downloaded: 35 times, Dimensions: 1608x806px
Size: 799.8 KB, Downloaded: 38 times, Dimensions: 1581x779px
5590.24 In reply to 5590.23
Hi Martin, it could be possible that it's kept as a kind of "analytic blend" in your first example that looks better, rather than it calculating a full NURBS surface which it needs to do for exporting to other applications. The problem is that it is also likely that it will calculate a NURBS surface result in various other situations as well like when there's an offset or intersection that needs to be performed on the analytic surface. So if there is some kind of degradation happening at export, it's pretty likely that the same kind of degradation will also happen in a variety of modeling operations as well.
In fact if it is not quite as bad in the initial display in ViaCAD that's quite a big can of worms in itself because it means you're not at all operating with a "What you see is what you get" system - that's quite troublesome if things look ok at runtime but then fall apart with major changes in surface structure and quality when you go to do some final step like export...
But also another problem though is that it's hard to see anything for sure in those screenshots that you posted due to the very poor quality of the display - notice how there is an abundance of jaggedy triangulation artifacts everywhere that you look in every screenshot - the triangulation being used to display the surface is just too coarse to be able to really see what's happening with the small details of the surface. This often times can completely disguise surface quality issues with ripples and bumps.
Think of it like this - say you have a surface that has a bunch of little squiggles in it, when viewed from the side it might be shaped like this:
But say this surface gets triangulated for display coarsely with only a few triangles say like these 5 points here:
When this happens the shaded display (which is just done purely from the triangulation) can easily look like the surface is all nice and regular and smooth, but what really happened is the triangulation is too coarse for you to actually see all the true details of the surface.
Now compare those screenshots that you posted where you can see all kinds of triangle artifacts, to this one here that I took in MoI:
Notice how in this screenshot you cannot see any trace evidence of triangulation whatsoever?
If you can't get the ViaCAD display to this same level of quality removing all triangulation artifacts, and getting to almost one triangle per pixel (or close to that) you won't really be able to say for sure if the original surface before export was actually less wiggly in some way or not...
So does exist a perfect N sided patch mecanism somewhere?
If yes, just copy past only this perfect 3dm "corner" inside Moi and resize it to the model ?
with oriente / line/line
(copy the half dozen of possibilities for have a sort of little familly of corners for adaptation to the corners wanted)
That maybe can avoid some times of difficult research?
EDITED: 9 Dec 2012 by PILOU
5590.26 In reply to 5590.25
Hi Pilou, it could be possible that a Parasolid based modeler like SolidWorks or NX might do a better job.
But even on a box the shape of the patch is a little different depending on the particular radius and setback values used, it's not like there is only one single corner shape that fits every kind of case...
The type of solution that you're talking about with just reusing one specific surface would only work on one shape and one set of parameter values.
5590.27 In reply to 5590.24
Hi Martin, I played around some with your original ViaCAD file inside of ViaCAD and yup definitely it looks a lot better there, and I think it is probably due to it being handled as a special analytic blend surface at runtime in ViaCAD and then having an actual separate NURBS surface result generated for exports.
You can also see a NURBS surface generated if you turn on surface control points for that one surface in ViaCAD and move just one single control point (on some far off corner of the patch so as not to actually change much with the edit itself) - that converts the surface into a regular NURBS surface directly in ViaCAD and if you then paste back the original blend you can see that the control-point edited surface has those ripples in it and is slightly differnet in shape than the analytic blend.
The analytic blend seems to be handled by a lot of mechanisms though, intersections and offsets do not seem to degrade it so that means that they implement the special blend surface type deeply into the ACIS system and it's able to do a lot of processing on the kind of "ideal blend surface" and not need to use the NURBS surface version for too many places except of course for doing a file transfer out of the ACIS system to some other system that wants to deal just with plain NURBS surfaces, at which point the messier NURBS surface approximation of the blend gets used instead.
This does not bode all that well for trying to integrate ACIS into MoI just for some particular operations like fillets though, because in order to get the nice n-sided blend behavior the surfaces have to stay as those special ACIS blend surface types and not get converted into regular NURBS. So that means keeping all things as ACIS data all the time and not just using bits and pieces of ACIS to calculate NURBS surface results.
So anyway I think that's what's going on there, that there's a deep treatment of these n-sided blends as a special surface type in ACIS which seems to work nicely if you stay all inside the ACIS system for all the operations involved but the NURBS approximation result is not all that great...
5590.28 In reply to 5590.27
I found out how to do a super dense mesh in ViaCAD - you can do it by right-clicking on a surface and picking "Change object type" to a mesh type, that has some controls including edge length control which can be used to make a really dense mesh object. I did that with the original blend surface and it definitely does not show the same kinds of problems as what you get from export/import.
So I'm reasonably sure that it is indeed different than the exported one and that it's probably treated as a special kind of surface in ACIS and when it gets that special treatment it's able to look nicer than it does when converted to NURBS.
Anyway, it's pretty good for me to know about this particular inter-op problem with ACIS,
5590.29 In reply to 5590.28
And in ViaCAD I am seeing some operations that end up using the NURBS surface, offsetting does seem to do it - if I take the nice looking N-sided patch by itself and thicken it into a solid with a thickness of 10 units, those same bumpy areas appear in the offset surface (here converted into a dense mesh):
So it seems that sometimes you get things calculated off of the ideal logical blend surface, and other times stuff happens on the approximated NURBS surface that's along with it.
5590.30
I know this isn't what you were looking for but this kinda gets you there:
(i patched a bunch of surfaces together and joined, although I realize this process is generally frowned upon)
5590.31
Hi Michael.
Another splendid explanation as to what is going on here - thank you.
So it looks like ACIS can make nice surfaces, but is apt to throw out a lot of the good work further down the line. I think that may explain why I've noticed changes to (complex-ish) faces of solids when I've done something like join them within ViaCAD.
My question is whether this hugely degrading 'feature' is entirely down to ACIS, or is likely to be some unfortunate error in how ACIS is being implemented? A case of "Snatching defeat from the jaws of victory", if ever I saw it!
http://doc.spatial.com/qref/ACIS/html/modules.html for anyone with an interest and can comprehend it :)
Cheers.
Martin (2).
5590.32 In reply to 5590.31
Hi Martin,
Well, the "error" part is just that the actual ACIS "fit NURBS surface through n-sided boundary" mechanism seems to have a bunch of the problems that are just pretty typical to that class of operation which is a tendency to have bumps and wiggles in the generated result. Wiggles are pretty much a natural byproduct of constraint based fitting mechanisms.
But they are able to mask that problem in many cases because they do have a nicely performing "analytic n-sided patch" surface which is able to be used instead of the NURBS surface for quite a few operations. Any operation within ACIS that is able to use that analytic surface instead of the NURBS surface will behave really nicely. Any operation that actually needs to operate only on a NURBS surface rather than a more abstract analytic surface (export being a prime example) will then have the less nice fitted result come into play.
Whether this is good or not I suppose is open to some interpretation and dependent on what in particular is being done - I guess if you only end up doing the particular things where the analytic surface is able to be used then the lesser quality one is totally masked and never comes into play and you could say that is a good result for that particular case. If you do end up doing something that needs the NURBS result then this sudden quality shift is probably pretty surprising though. And it's bad news for NURBS data exchange certainly.
5590.33 In reply to 5590.32
Hi Michael.
In one way I was hoping you were going to say that it was poor integration of ACIS into ViaCAD, because that can be worked around.
If ACIS really is this flawed - and I don't doubt your word, I just can't quite believe this chasm of quality exists within it - then it does seem to make the notion of moving files between applications very hit and miss and not something to be done without some serious thought first.
I can understand a poor input surface being responsible for generating a poor output surface (GIGO), but I do struggle a bit with good going to bad, especially if it's not flagged in some way.
As a last grasp at this Michael, do you (or anyone else, reading this) have some other ACIS based software that you could try importing the SAT file contained in my zip attachment, and check whether/how the problems persist there?
Cheers.
Martin (2).
5590.34 In reply to 5590.33
I didnt have another ACIS based system to look with, but here's a quick look at ParaSolids Handeling of the file. (Autodesk failed to load the SAT file)
Note how converting the surface to NURBS actually has Parasolids reconstruct the trim boundries completely different.
It's a good view to see how different kernels will do things differently. Interoperability has always been a burden. All the understanding will go along way in helping people get results. Parasolids will do the same thing to other kernels. The higher end fancy stuff doesnt go around "generic" or you wouldnt need higher end fancy stuff.
It's a good lesson for anyone who would "blame" a software. ACIS isnt really doing anything "BAD". If you keep the analytic surface analytic surface, then it's perfect!
5590.35 In reply to 5590.34
Hi Burr, can you try importing the version attached here without any fillet into Parasolids, then do a fillet with a setback to generate a new fillet there and then export that back to STEP and post it here? It would be interesting to be able to compare the Parasolid generated n-sided patch at the juncture area.
5590.36 In reply to 5590.33
Hi Martin,
Well I can't say for certain that is not the case since it's not like I have any specific information on the internals of ViaCAD.
But it seems doubtful that it would be a problem specific to only ViaCAD rather than ACIS itself.
I gave it a quick try with Alibre, and it's hard to see for certain but it appeared to open with the lumpy surface in place from the start, which probably means that Alibre converts these kinds of analytic surfaces into plain NURBS , either that or it uses the NURBS version of the surface for its display.
5590.37 In reply to 5590.35
FYI here's a couple from NX the 'NX_default_fillet.3dm' is using the default filleter with setback in NX, to get an n-sided surface that's a seperate feature shown in 'NX_n_patch.3dm'.
5590.38 In reply to 5590.37
Thanks Danny. I couldnt provide the result because i use a version which requires me to pay to export out a model. I was going to ask you anyway :o
I didnt do the fillet (lack of understanding). The autodesk filleter made the star fillet method the same as the nx file Danny Posted.
Here's a video of doing the original patch to show some of the results (Not the same as reviewing the file, but an idea of how they are doing it)
It looks to be somewhat the same as Rhino's. The other thing to note is doing the patch ion the extended part to get a smooth surface. (Kindof one of your mantras Michael).
Anyway, Cant provide the file, but maybe some others with solidworks or something could present something.
Show messages:  1-18  19-38  39-58  59-75
