Architecture test..
All  1-2  3-12
558.3 In reply to 558.1
Wow, that is so cool, I can't believe that is your first test!
Great work!
How do you like working in MoI after your first test? Did you run into any major bugs or problem areas or things that you wished worked differently?
558.4 In reply to 558.3
Thanks for all comment! I think that MoI is very intuitive.
I didn't run into any bugs.
558.5 In reply to 558.4
Hi Spezio
Can you post your 2 images in this thread about Moi http://www.pushpullbar.com/forums/showthread.php?t=4216
It's one of the more interesting forum about Architecture & Design & Sketchup ; )
The thread was started by a "Super Moderator" so no problem :)
Images must be resized max 700*700, one image by post
558.6 In reply to 558.1
Very cool!
558.7
very nice work SPEZIO 8*)
Hi Spezio
Thx for the posting at Pushpull bar ! :)
Ps You have made direct link image (and that is not the forum rules so some guy cry :)
like this one
"can you use the the "manage attachments" button, to post images, as per the forums rules. You can edit then "go advanced" then scroll down and you'll see the button
thanks, actually at a computer where your images are just grey squares - blocked or something, I dunno but want to see..."
Images must be resized max 700*700, one image by post (195 kb max /jpg)
EDITED: 24 Apr 2007 by PILOU
558.9 In reply to 558.1
What software did you use for the render?
558.10 In reply to 558.9
To PILOU: the dot-square are caused by jpg compression, i've uploaded a new image
to Michael: maxwell
558.11 In reply to 558.10
MAXWELL!!! Always the best
You modeling is great!!!
***There is always a better way to do things... Just find your Moment of Inspiration***
558.12 In reply to 558.11
Yep, Maxwell makes amazing stills and it looks like it has a great material library. Version 1.5 sounds like it will be great, especially with the added Linux support. For those on a budget try Indigo, which is free and has a great community. I have seen comparison renders and Maxwell is faster with arguably better results, but Indigo is still impressive. I have been running it on my spare Linux box under Wine.
Once again, great work. I enjoy seeing architectural and environment pieces made with MoI.
Show messages: All  1-2  3-12
