SoftImage will be using "SI Units". These can be defined as anything. Just units. It appears that the intent is 1 SI units is actually 10cm. The input fields accept math functions, so you can define with that in mind. Alternatively, you could just work as 1 unit is 1 unit, then figure out the scale factor when the time comes.
