Hackintosh & MoI
All  1-9  10-15
5575.10 In reply to 5575.9
Hi Martin, yup that change that I posted before will only modify "command buttons", those are the type of buttons that have an icon with smaller sized text underneath them - when you had mentioned something about "words sitting on buttons" I had thought you were asking about modifying just these kinds of buttons, but I guess what you meant by that was just if the bolded text would fit or whether it would get chopped off. The fitting part should not be a problem, the UI will expand automatically to accommodate the slightly larger bold text, that ability to make controls adapt to text size is a fundamental part of MoI's whole UI mechanism.
So would you instead like to have all text in every spot in the UI as bold? If so then it's possible to do that by modifying one line at the top of the moi.css file instead, go to the rule at the very top of the file (the one for "html, body"), and add a font-weight:bold; to it so that it looks like this: (again the >>>> <<<< shows the added line, don't actually add the>>> <<< characters themselves):
html, body {
    color:#000000;
    width:100%;
    height:100%;
    margin:0;
    -webkit-box-sizing:border-box;
>>> font-weight:bold; <<<<
That should then get pretty much all text to be bold - I think about the only thing that won't be bold would be the object snap tags that are displayed inside inside of the viewport and the shortcut key editor, those are on somewhat different systems than the rest of the UI. And I guess a couple of other assorted minor things like tooltips would not be bold, but for the most part it should do it I think.
By the way if you want to see a really funny UI customization, go to moi.css and "uncomment" (remove the /* */ around them) the 2 rules at the very bottom of the file. Maybe not if you tend to get vertigo though... ;)
5575.11 In reply to 5575.10
Yeap, that makes it even better regarding text, but oh boy what was you thinking with the other, lol. You just knew i would have to play with that didn't you. What was even more surprising though was that it affected everything other than the drawing area, i expected the whole display to rotate by steps of 45 degrees. It would however make for a nice transition effect for those who want to be able to move their menues about, e.g drawing toolset to the top of the screen and the browser to the left etc. Nice bit of trickery, but as you say, totally unworkable, trying to click the buttons is amusing as they keep moving out of the way.
Nice feature .... I think :\
Martin Spencer-Ford
5575.12 In reply to 5575.11
Hi Martin, yeah I thought you would get a kick out of that one! :) It's pretty funny how the UI actually functions when that rotation is going on if you can manage to actually click on things.
The sort of top level layout is basically a custom layout mechanism, that level is not handled by HTML, mostly because the viewport 3D display area is pretty much a separate thing from the GUI / buttons type area.
The top level layout handles a kind of generic "panel", and there can be ViewPanel that hold the viewports, and UIPanels that hold HTML content. Things like dialogs and flyout menus just have one UI panel in them.
This structure actually ended up helping quite a bit when I did the big transition from IE to WebKit - MoI v3 (and v2.52) use a completely different HTML engine for the UI panels than MoI v1 and v2.0.
5575.13 In reply to 5575.12
It would be a niffty trick to pull on someone when that have had a little to much beer/wine etc.
It's all clever stuff, I got about as far as playing with Dynamic HTML many years back (10 or so) but decided web design was not for me, trying to maintain client sites and still finding time to design new ones was getting too much.
Martin Spencer-Ford
5575.14 In reply to 5575.13
Hi Martin, yeah definitely Dynamic HTML has a whole lot of its own quirks, I invested a lot of time back about that same time period before getting comfortable with it. It tends to be particularly good in the area of handling text though, with a lot of features involving text layout, word wrapping, and sizing things to fit child content. These are the reasons why I've persisted in using it for application UI for quite a long time now. And it's also the closest thing that exists to a global cross-platform "known by many" type of UI. Also it's had scripting built into it for quite a long time and the ability to bundle script code along with the UI in one package is very flexible.
5575.15 In reply to 5575.14
Yeah, I could see the potential for it, but flash and css came along and DHTML seemed to drop from flavour of the month to the poor mans tool. But yes it was good for animating text blocks and adding some cool mouse over effects, i miss animation at times, but I am happy to tinker with my 3D hobby. I used to do programming too, but then .net came along and i lost the whole logic and struggled so that got abandoned too. But that was done purely as fun and for my own system checking tools. Who knows, one day I might go back to it.
Martin Spencer-Ford
Show messages: All  1-9  10-15
