Checkbox in "Align"
All  1-4  5-8
5533.5 In reply to 5533.4
Hi ed, yeah I've thought some before about a kind of "snap to curve" mechanism for Align, but I haven't quite got it all figured out how it would work yet. One problem is that Align already has a lot of options and adding too enormous amount of options to any one single command tends to be unwieldy.
> Reading this I think maybe it could work with curves and solids too.
There is already a command for projecting a curve onto a solid, it's under Construct > Curve > Project.
5533.6
I'm talking of something like "move to closest point on object", without deforming. If you have for example two circles you could pick one, trigger the command, choose the second one and then MoI moves the first circle to barely touch the second one.
5533.7 In reply to 5533.6
Hi ed, I see - something like that I guess would probably fit under a kind of "collision detection" or "point of first contact" mechanism. But unfortunately it would be a pretty major undertaking to make one that worked on all cases, a convex shape like a circle is not so difficult but to do a proper job on arbitrary shapes that have little bits and pieces sticking out at various spots becomes a much different matter.
If you just want to do 2 circles like you mention, you can do that particular case already with the Move command - start up the Move command and before picking the base point drag out a construction line between the origin point of both circles, it will then intersect the circles at the "closest point" spots and you can snap on to those intersection points.
There may be other already existing solutions for other kinds of shapes as well, if you have some particular example other than the circles where this would be useful if you could post that I'll see if I can give you a solution or it may help to get some idea on if there is some particular feature that could be developed to use as one step of the solution.
5533.8
It was just an idea. I saw some potential on that because it is very intuitive, it works like objects in real world, as you said, like collisions. Now, for the points it could be very helpful to have something like you described before, an align to curve... it may be a project to closest point on curve, but again, just an idea that came to my mind when using MoI, nothing that cannot be done right now but with more steps... Thanks for your replies.
Show messages: All  1-4  5-8
