V3 beta Nov-6-2012 (Win/Mac) available now
 1-15  16-35  36-55  56-75  76-95  96-115
5524.56 In reply to 5524.55
Seems a customised UI was asked from numerous users from a long time :)
5524.57 In reply to 5524.55
No..you're not the only one..i think Michael keeps to mantain a clean "zen" interface(this is one of the best features of this software)
but the scripts are growing very fast,so a choice to add a button somewhere in the UI just for your favourite scripts could be a good compromise
you know..press CTRL+A or ALT+X etc...and remember all them..it's not exactly a clean and fast workflow..
5524.58 In reply to 5524.55
Hi Rich_Art, I definitely want to make the UI more easily customizable in the future. It involves a lot of work though, and currently I've placed a higher priority on other areas of work like bug fixes and new modeling functions.
I expect in the future it will come in some stages, like probably some kind of plug-ins menu where you would be able to see a list of installed plug-ins will probably be first at some point before some kind of more extensive UI customization mechanism.
Those things do not really block you from doing actual modeling though, so things like new modeling functions are just more important to focus on before that though.
The keyboard shortcut mechanism is also pretty primitive, and I'm definitely aware that it will need some attention too, like it should be possible to assign shortcut keys more easily by just pressing the key that you want to assign rather than typing in a label like the current method. Again, that's just a matter of priorities.
5524.59 In reply to 5524.57
Hi Mauro,
> for your favourite scripts could be a good compromise you know..press CTRL+A or ALT+X
Really the main solution right now for this is to just not install so many scripts, especially ones that you don't regularly use.
If you don't install things you don't need, then you don't need to worry about keeping track of them either... ;)
But actually though, it is certainly true that MoI is just not currently optimized for this kind of "lots and lots of scripts installed" kind of case. But it's all a matter of priorities, do you really want me to focus on a big overhaul of making an elegant UI for managing all your scripts or would you rather that I work on improving Blend so that you can actually construct surfaces better than you can right now?
Basically the existing keyboard shortcuts and scripts mechanism even though not ideal works well enough that it's hard for me to justify putting an overhaul in that area as a high priority.
If you're having problems remembering things you can always do something like write yourself a text document that helps keep track of things for you.
I do expect that it will get overhauled eventually, but I'm not sure exactly when.
5524.60 In reply to 5524.59
Michael:
<<do you really want me to focus on a big overhaul of making an elegant UI for managing all your scripts
or would you rather that I work on improving Blend so that you can actually construct surfaces better than you can right now?>>
no dubts...modeling tools !!
Michael:
<<If you're having problems remembering things you can always do something like write yourself a text document that helps keep track of things for you.>>
In my case i think it depends by natural aging (i'm 50+ two weeks...years old)
5524.61 In reply to 5524.60
i'm also getting older and have a hard time to remember all those short cuts, but i don't complain.
I also understand that this might be a lot of work to integrate a proper solution for this in the UI layout.
Therefore my question, wouldn't it not be possible and much easier to add a pull down menu entry
called "Scripts" near the Window/Help Top Menu Bar, so that it doesn't add up to the UI layout?
Well, just a thought.
Best regards
EDITED: 30 Oct 2016 by STEFAN
5524.62
>or would you rather that I work on improving Blend so that you can actually construct surfaces better than you can right now?...
Hey guys! Careful! This improved Blend is my Christmas. ;-)
5524.63 In reply to 5524.61
In Windows' system we have not this Menu line in normal use of Moi!
The "help" is on the page bottom button, you have not the same in Mac's System?
5524.64 In reply to 5524.63
Hi Frenchy,
sorry, didn't thought about the Win UI!
On the Mac we have both the "Help" at the top menu bar
and like in Windows on the bottom right the help symbol too.
5524.65
I just tried the latest Beta.
Windows 8 professional x64 -retail
Asus EP121 slate
Intel graphics
Core i5 processor
I'm getting black surfaces, artifacts, freezes and all kinds of other graphic glitches. I really wanted to use the isocurve extraction but the viewport goes white when I try to select. Apparently this beta is unusable for me.
Isaiah
5524.66 In reply to 5524.65
Hi Isaiah,
Was the previous v3 beta working ok for you? Or were you previously using v2 and this one is the first v3 beta that you've started to use?
The stuff you are describing sounds like video card related problems, I would recommend seeing if you can go to Intel's web site and download the latest video drivers for your video card and see if updating that has any effect. Typically the kind of stuff you're seeing is related to buggy behavior with the video driver.
One of the new features in v3 is the use of multiple CPU cores with the display engine, maybe you're running into some problem related to that. You could try disabling that by editing moi.ini (go to Options > General and push the Edit .ini file button), and in the [View] section find the entry for DisplayThreadLimit and set it to 1 so that it looks like this:
[View]
DisplayThreadLimit=1
Does that do anything?
5524.67 In reply to 5524.61
Hi Stefan,
So yeah like Pilou mentions the problem with that is that menu only exists in the Mac version and is not present in the Windows version.
Since MoI works on both the Mac and Windows as well I can't really use a design that would only work on one system and not the other.
5524.68 In reply to 5524.67
I understand! I didn't thought about the difference in the Windows vers, sorry!
Best regards
5524.69
Thanks for the quick fix, I'll try it...
A sequence that always lead to the second problem (the numeric input field not being highlighted) is making a rectangle and then extruding it via shortcuts. Try to set up shortcuts for those two commands and then you'll see (hopefully) that you can't enter a numeric value for the extrude.
5524.70 In reply to 5524.66
My Intel graphics drivers are up to date and I played with the number of processors from 1 to 4. Strange graphics performance every time.
IC
5524.71 In reply to 5524.70
Hi IC,
Then it's possible that it's actually the latest driver that has the problem in it and you may need to install a slightly older version of the driver instead until the latest one is fixed.
Did the previous v3 beta work ok for you or was this one the first v3 beta that you had tried?
5524.72
The new offset command works perfect. I tried again on both the 2.5 and the latest beta and I cannot replicate the highlighting problem, but i found the thread where it was discussed earlier: http://moi3d.com/forum/index.php?webtag=MOI&msg=4983.1 If I find a way of pushing it to happen then ill let you know.
5524.73 In reply to 5524.69
Hi ed,
I couldn't replicate any problem with that over here. I set up a shortcut for R for rectangle, and E for extrude, then pushed R, drew a rectangle, selected it and pushed E then typed in 20 (or any number) and it worked fine for me... This is on OSX 10.7.2 Mountain Lion.
Do you possibly have any shortcuts set up with a number key being the shortcut key? Having things set up like that can interfere with using the number keys for numeric input.
What are the exact keys that you have set up for extrude and rectangle, do they use a Cmd key combination or just a single letter?
5524.74 In reply to 5524.72
Hi ed,
Sorry I hadn't remembered that previously.
From what you said there though it sounds like you may have some shortcut keys set up which are capturing certain keys for use as shortcuts rather than for use with numeric input.
If you want to use auto-focus numeric input, you should not set up any shortcut keys that use any of the following keys as the shortcut trigger: 0 1 2 3 4 5 6 7 8 9 - .
If you do set up any of those as a shortcut key then when you push that particular key MoI will see that you've set it up as a keyboard shortcut and will then trigger the shortcut instead of any of the regular keyboard processing happening.
Let me know if that's not the problem you were running into and what steps I can do to recreate the problem, so far I have not been able to reproduce any problem with the focus behavior over here, the steps with rectangle and extrude that you mentioned before did not cause any problem over here.
5524.75
Using the Offset line tool.
With the shown settings, is this the expected result for the end-caps, or should there be a radius at each end?
Martin (2).
Show messages:  1-15  16-35  36-55  56-75  76-95  96-115
