New tutorial
All  1-4  5-7
5518.5 In reply to 5518.4
I think SVG is the only importable vector format supported by Substance Designer. A lot of image resource files are supported, but I only see one file format I know for sure is vector-based and that is SVG. If Inkscape would open the version of .ai that MoI outputs, it really wouldn't be a problem. I could just push the MoI-generated .ai through Inkscape and export an .SVG from there. I can approximate things by using Inkscape's trace tools, but it's a tad unpredictable and requires more cleanup than is useful.
Inkscape does import DXF and PDF, too, I think. If I could go from MoI-to-Inkscape-to-SD via DXF of PDF, that would make me just as happy. After getting an idea of the magnitude of the task involved in getting SVG working I totally understand other things taking priority. And I also realize that I am asking for a feature that is kind niche. And it's a feature I would use for very specific instances, so it's not a huge deal. Thanks for directly addressing it, Michael. Appreciate all the work you do for us!
5518.6 In reply to 5518.5
oi surlybird!
did you try uniconvertor?
http://sk1project.org/modules.php?name=Products&product=uniconvertor
it says command line tool on the package, but it actually got some kind of ui (in windows at least). eats MOIs-.ais and converts them into .svgs.
~marco
EDITED: 2 Nov 2012 by MARCO
5518.7
And...problem solved! Thank you, Marco! UniConverter works like a charm! I had never heard of it until you mentioned it, so you have my eternal gratitude. This made my day!
Show messages: All  1-4  5-7
