Feature request for MoI v3.
 1-7  8-27  28-30
5503.8 In reply to 5503.5
Also is this something that would only go in the properties panel, or would it go on every edit field that shows units?
Because on a lot of them the value in the field is pretty dynamic, like when you're drawing a circle inside the circle command, the field changes when you move the mouse and if you type in a single value there it finishes the command. So for cases like that I'm not sure that you would get anything from having a converter widget.
The properties panel one is different from that that one is showing you the properties of an existing object. So would this only go on the properties panel and not on just every edit field?
Also when you pop out the edit panel when your object is not a line or a circle when you open up the "Edit size" dropdown, there are multiple fields there, not just one, and also multiple units labels one for each field.
Like if you select a box and then open up the edit size panel you get this:
So would that be weird that you would do this unit conversion thing on only one of those fields at a time?
5503.9 In reply to 5503.7
Or would it be that you'd see this units popup by clicking on the units label on this spot here instead:
5503.10 In reply to 5503.9
""""Or would it be that you'd see this units popup by clicking on the units label on this spot here instead:"""""""
I would think that, and "Only" in the properties panel. I think you calling it a "widget" is more correct. Nothing would persist. It clears as soon as the object is de-selected.
I should stop and let the original poster respond. I may have gotten his intent wrong.
5503.11 In reply to 5503.9
Hi Michael, That's the place i'd like to see it with a drop down box to select secondary units, or just to have a list of them displayed under one another, you have the room there for that.
Martin
5503.12
Thanks for the responses, chaps!
I think that BurrMan got the idea in his first reply, and the last three posts above this one seem to have just about nailed it. Michael's red arrow is pointing to the area I was refering to (in reply #9).
This would give a level of convenience comparable to Radius/Diam toggle and useful for people like me that often have to work with drawings that have mixed units within them.
It would be nice to have the option that any particular entity could retain the unit setting for display when reselected for editing, but I understand this may make things more complicated - I'd be happy enough to have the conversion revert back to the default system units when the item is deselected if that's more straightforward.
Thanks.
Martin.
5503.13 In reply to 5503.12
So I've been giving this a try, but ran into a roadblock of a current limitation that flyout menus are not set up to change size to adapt to content changes (like when different length text is displayed when different units are switched between on the flyout).
But I'm going to see if I can enable that in the UI system since it's been a limiting factor in some other things before too.
5503.14 In reply to 5503.1
Ok - this is what I've been able to come up with, does it look like it will do the trick?
5503.15 In reply to 5503.14
hey michael
that does look good...and this will only affect that specific selection, or does it change the unit system for the whole document?
thanks,
marco
5503.16 In reply to 5503.15
Hi marco, it's like a "quick view" of that size information in different units. It doesn't change or edit anything about the geometry or the document, it's just for displaying that particular size value in other units just while that menu is open.
5503.17 In reply to 5503.1
Hi Martin (original poster) - ok I think I now fully understand what you were originally asking for which is a way to change the units being displayed directly inside of the properties panel.
So yeah that would worry me about people wandering across this feature by clicking on that spot and then not really understanding what unit setting their file was actually currently set to, I could see someone pretty easily thinking that they had changed the units for the current overall document by switching the units on the panel only.
The way that I've shown in that screencap should help avoid that kind of problem since I think it will be clear that it's just "peeking" at different units just in the popup alone and not actually altering anything. Or at least I hope it will be understood that way.
Maybe it will be possible for me to put in a hook that will enable a script to be set up to do alter the units being displayed at the top level in the properties panel, I'm not so worried about someone getting confused after running a specialized script as I am about someone clicking on things...
5503.18 In reply to 5503.15
That looks cool Michael....
Don't know if I ever gonna use it but it is a nice feature...
Peace,
Rich_Art. ;-)
5503.19
Michael.
In my dreams it would be nice to have a kind of 'local units' feature for any particular item in the drawing, but I do realise that this might be a large undertaking to ask of you and I don't really know if it's a practical thing to request.
I much appreciate the work you have done on this and it will be a big help, because the 'calculator' will be right where I need it, assuming of course that it actually ends up in MoI. In short, I'm 100% happy with the example of the feature in use, it should also be handy for scenes that contain a mixture of large and small items as well, I think.
Martin.
5503.20
Looks spot on for me ... Good job Michael, will it be staying ?
Martin Spencer-Ford (No confusion)
5503.21 In reply to 5503.14
Nice conversion.
Should there be any indication that this is an approximate value, rounded to 2 decimals?
Line Inch +/- ?
Wondered if more decimals would be displayed with other settings?
5503.22 In reply to 5503.19
Hi Martin,
Hmmm yeah I'm afraid that does not seem likely since there would have to be some accompanying UI to control such a thing and it would have to be pretty carefully designed in order to avoid creating confusion between the "file's units" versus "this particular object's units".
Confusion over what units are actually active can possibly lead to pretty big errors so it's not generally an area that I feel very comfortable doing too much experimentation.
Yup, I think the 'calculator' thing as shown will be safe to have, and I have that implemented now so it will be in the next v3 release.
I will also see today about making it possible to use a script to change what units are being displayed directly in the properties panel so that it will be possible to set up keyboard shortcuts to switch that around.
5503.23 In reply to 5503.20
Hi Martin,
Yup, I don't think that it should cause any harm so it will be in for the next v3 beta.
5503.24 In reply to 5503.21
> Line Inch +/- ?
It uses whatever display precision you have set under Options > General > Decimal display, which controls the rounding of all values that are displayed in the UI in general. If you change that setting to show 4 decimal places, then this pop-up will show 4 decimal places as well.
The popup has more room available than a lot of UI that has to live inside the side pane, so I suppose it could be possible for me to use more decimal places than your regular display precision setting... But when I've tried that in the past people have also asked why some particular UI is not using the global setting.
5503.25
Michael.
Well, what can I say, except thank you!
I've only had MoI five minutes and you've already gone out of your way to build in one of my requests - this really is first-rate service.
Thanks again.
Martin (2).
5503.26 In reply to 5503.25
Ok, so I have also been able to set it up so that a script will be able to change which units are used in the properties panel for the main display, so that means that it will be possible to set up a keyboard shortcut to switch the display there between the current file units and inches for example.
There have now been a lot of changes around that units display now so please be on the lookout for any bugs in that area in the next beta. I'll try to get out a new beta at the end of next week I hope.
5503.27 In reply to 5503.26
So the script will be a "conversion for the properties panel display" only. No actual document unit changes, and no "per object" units. Correct?
Show messages:  1-7  8-27  28-30
