Hi Burr, yup that's correct, the script will control what units to use for converting just the Size: display in the properties panel, not actually change anything in the model just change the display readout only.
It will just be another option to do the same kind of thing as the pop-up menu, just if you're frequently switching between a couple of different displays you can set up a shortcut key to do it more conveniently.
