New Apr-18-2007 beta now available
 1-5  6-25  26-41
550.6
i LOVE the curve projection !!!
550.7 In reply to 550.1
Thanks Michael,
I'm looking forward to trying out the new features! :)
Je
550.8 In reply to 550.1
Hehe... I was out for couple of days 'cause I was busy and I can see that you are still working pretty hard...! Let's hope that I will be able to spare some time and try new beta out and read all new posts as well.... -Petr
550.9
thank you Michael :)
ciao
torolf
550.10 In reply to 550.1
Thanks Michael G.! I can't wait to get home and try it out tonight!
Michael Tuttle a.k.a. mictu www.coroflot.com/fish317537
550.11
This is very good news! Thanks Michael!
***There is always a better way to do things... Just find your Moment of Inspiration***
550.12 In reply to 550.1
Thks for your wonderful soft Michael.
Can u explain again how to use the new div snap option cos I cannot find it anyway.
550.13 In reply to 550.12
Hi Aeron - here is a better explanation.
To use div snap first you must create a construction line. You create a construction line when you are in a drawing command (for instance Draw curve / line) by clicking and holding down and dragging the mouse instead of clicking and releasing.
After you have done a click + drag to create a construction line, there will be a little tag that appears above your mouse:
If you move your mouse over that tag, it will light up. Click and hold down for a moment on that tag and it will launch a menu, this is where you can define div snap:
For example if you want to snap to thirds along that line (1/3, 2/3, etc..) then put in "3" in that Division snap box.
The divisions are defined between the 2 endpoints of the construction line that you drew. When you draw a construction line, it is defined by 2 points, the point you start the drag at, and the point that you released the mouse over.
Here for example I dragged out a construction line between the ends of 2 other lines, and set up a div snap so now I can snap to 1/3 the distance between those endpoints:
The divisions continue along the entire infinite extent of the construction line, so you can also snap to spots like 41/3 or -7/3, etc... , so it is possible to use the div snap as a type of quick custom spaced grid line.
Let me know if you need any more information on any of the above stuff.
550.14
Woaw ! Terrific new features there !
I did not even had the time to test the previous version and here is a new one ! ;-)
Michael, I will not say that you're doing a great job or that your software rocks, it's too trivial !
What I will say is that if you come to Belgium one day I will be pleased to pay you some beers ! ;-)
550.15 In reply to 550.14
Great great stuff, as usual.
You're about to create THE software that will open NURBS to "standard" polygonal users and hobbyists.
If one day the "NURBS way" of creating objects is used by a lot of persons, you can bet you will be the one that will be responsible for the whole thing.
Pilou started a thread here, in France at www.zbrush.fr, at http://forum.zbrush.fr/index.php/topic,1463.0.html
Pilou and Schbeurd present the new functions as soon as you create them. Thanks to them, french users of Zbrush and visitors of the forum can view the wonderful work you realize. I wish to thank them for their great work, their help, and you for this marvelous piece of software.
Alexis
550.16 In reply to 550.15
>> Thanks to them, french users of Zbrush and visitors of the forum...
You mean french speaking users of ZBrush... ;-)
Added a summary of the release note on ZBrush.fr and on the French forum here at Moi3D
Thanks for the kind words Alexis ! ;-)
550.17
Once again, awesome work Michael!
Looking forward to poking around with the new features!
550.18
"Gordon surface"
thank you Michael...
those who ever worked with Studiotools can understand why this is one of the most wanted feature...
next one is progressive radius fillets / chamferts....
i hope i'll be able to buy moi3D v1.0 for my school within next summer hollydays...
regards.
550.19
great new version. The curve projection stuff is the most usefull feature to me. :)
I've updated the German translation.
MfG
sk2k
550.20
Thanks for this update Michael! I haven't been playing with MoI for the past week, but am looking forward to modeling something this weekend with the new beta.
550.21
I have two notes concerning the new beta...
Are you going to tune network surface command up so it can also handle non-intersecting curves? And what about some tolerance input for driving a surface? It would help users create a surface from roughly sketched curves.
For projecting I wish I can deselect unwanted projected curve by clicking on it (or in a different way) before command is done. It makes sense when curve is projected on both the closest side and opposite one (e.g. circle and sphere).
Petr
550.22
Spanish translation added.
New stuff translation added in the Spanish forum.
Enjoy it! :-)
550.23
Good job with the Network tool Michael. As simple as the image below, only the Network tool
could do it accurately. Of course there are other tools. You might want to try. ;-)
Btw, only four curves were used in this case. Three, lenghtwise, and one, crosswise, which is in the middle.
EDITED: 21 Apr 2007 by BLENDDOODLER
550.24
You could see these shapes in some mechanical part such as
the nose of an electric drill or handles.
Or as shapes to subtract from a boolean difference.
French translation Updated of 18 April 2007
Unzip and replace the file FrenchStrings.txt in the folder ui
EDITED: 22 Apr 2007 by PILOU
Show messages:  1-5  6-25  26-41
