how do I do this in "sweep"?
549.1
Michael,
again me, Rudy.
I want to create a solid, half-rounded loop with "sweep" option (see attachment)
But I cannot make this
I select the sweep button. select the profiles ( first the two half-curves, then the two connecting lines), when prompted for the rail(s), select the circle,
and nothing happen.
why?
Thank you,
Rudy
549.2 In reply to 549.1
Hi Rudy - in this case MoI thinks that you have 4 profile curves, and for sweep you can't have 2 different profile curves that attach to the rail at the exact same point, that's why it fails.
To fix this, select those profile curves and use Edit/Join to join the pieces together into one larger single curve.
After you join them, then the sweep will work as you expected.
Some commands such as extrude have a joining step built into them so you don't have to do it manually, but sweep doesn't do that right now. I guess I could add this into sweep, I'm not sure if I will be able to get to that for the V1 release though.
549.3 In reply to 549.2
Michael,
got it.
Thank you again.
Rudy
