Majik Tutorial: The Turbine-Style Sports Rim
 1-15  16-35  36-46
5470.36
Here is a neat interactive model of my sports rim (from Sketchfab.com)
Wait a minute or two for it to load then just click and drag to manipulate the model.
<iframe frameborder="0" height="700" width="800" src="http://skfb.ly/m4ji3hedca?autostart=1&transparent=1&autospin=0.1&controls=1"></iframe>
5470.37 In reply to 5470.36
By Default tire is White!
So White on white there is nothing to view before you move the mouse!!!
And after click and move you see only the center of the rim!
5470.38
Pilou, I set this up at my work, and it worked fine.
I just now tried it at home where my internet speed is slower.
It took it longer to load, maybe two minutes, and it moves very very slow because of my video card.
I noticed that all of the 'lighting' layers did not activate immediately.
It took the tire another 20 seconds before the rim, which was black, to become chrome.
I'm assuming this is 'Direct-X' operated.
This makes me wonder if users of Moi will have the same card-dependent performance issues when (and if) Michael adds material/UI view support for background reflection and more material and lighting options.
I may re-think using these interactive models if they're going to be slow for me to use at home... or I could allow them not to 'autostart'.
5470.39 In reply to 5470.38
For me it's loaded in a few seconds (statistics say that is 500 kb file), so for the color that must be old config of Direct X etc... :)
5470.40 In reply to 5470.39
Your looking at WebGL and what is rendering it will depend on the browser AND OS. My default Windows IE doesnt play it. WEBGL is nativley meant to run Open GL, but "2.0" I think, and alot of drivers dont run it or support it very well. Chrome and others use ANGEL to convert the OpenGL to DirectX.
There are many factors. My experience so far is Firefox runs the WebGL stuff the best, right out of the box. It worked on this particular model better than chrome. I didnt even try to load "ChromeFrame" on my IE to test it.
I would appreciate Microsoft to Enable WebGL but they have been against it for quite awhile. Maybe rightly so.
There is talk that Internet Explorer 11 looking to be released this month in Windows "Blue" has WebGL support signs built into it, but not implemented. I guess we'll see.
5470.41 In reply to 5470.38
All fine here using Firefox and Chrome
1 minute loading ,then all objects showed at same time(Nvidia GTX 460)
just rim wait 15 sec. to become chromed
Thanks Pilou,Didier and Mike !
M
Ok I have tested on another computer ;)
10 seconds loading on the forum
1 second for have chrome!
Fabulous Scketchfab and model ;) !!!
http://moiscript.weebly.com/jante.html (at the end of the page)
EDITED: 13 Jun 2013 by PILOU
and I have tested as now you can registered without Twitter facebook etc... ;)
5470.44 In reply to 5470.20
Excelent Tutorial ;)
But need a short tutorial for making the pattern, I did have made some patterns with illustrator too, so I can use also ai patterns?!
5470.45 In reply to 5470.40
Works great on my set-up.
Chrome under Windows 8.1 64 bit
i7 CPU
AMD Radeon HD 7800 video card.
5470.46
yes, but would be great to get a nice short tutorial for pattern making, mabye also in interaction with illustrator?! ;) I have some nice seamless patterns in *.ai ...
Show messages:  1-15  16-35  36-46
