Script for placing guitar frets
All  1-3  4-7
5440.4 In reply to 5440.3
Hi Martin,
> Is it possible to draw something i.e. a line or a box via scripting?
It is, but all that kind of stuff is set up more for how the drawing commands work where you're picking things interactively in stages.
The way it works for a line for example is that you create a line "factory", set the values for its inputs and then the factory can generate an output. In the line command the inputs come from the results of a pointpicker.
In the future I want to add a more simplified interface for scripts with something like just a moi.geometryDatabase.createLine( start, end ) type call but that layer is not in place at the moment.
5440.5 In reply to 5440.3
There's a plug-in here which creates lines which you might be able to use as an example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5136.1
5440.6 In reply to 5440.5
Thanks Michael!
5440.7
Martin and Gibson. But where is Fender?
Show messages: All  1-3  4-7
