Hi CarveTech - a shortcut key can either have a command name on it (just one) or some script code. So if you want to chain multiple things together in a shortcut key it has to be done with scripting and not just by putting several command names in a row.
But the sequence that you're describing would be duplicating an object and then using the Move command - the Transform > Copy command already does that same job already, so you can just put in "Copy" for the command name on your shortcut key to do that type of duplication + move combination.
Is there something specific about doing a clipboard copy and then paste and then move that is not covered by the Transform > Copy command ?
