Circle Tangent on a sphere ?
 1-2  3-22  23-27
EDITED: 30 Sep 2012 by BEMFARMER
Ok I have successful with use only the Orient and helper lines ! ;)
Same trick than my previous try for inspiration :)
Circle given is drawn somewhere on the ground: click on it for have the radius
Call the Orient
In view Front draw a vertical helper line from the top of the sphere
Move it of the radius given of circle
Redraw one vertical line at the Top of the sphere
Draw an horizontal helper line from the intersection of the previous vertical helper line of the radius and the generator curve of the sphere
Et voilĂ  ! :)
I can draw the Orient Circle at the good deepth!
After that just now take the top of the sphere as Base Origin!
And copy it anywhere!
EDITED: 30 Sep 2012 by PILOU
5435.25 In reply to 5435.21
Michael, did you look at the possibility of using the ArrayGem factory with Point Objects, rather than
lines or curves? (While preserving the On Surface normal orientation?)
Thank you,
Brian
5435.26 In reply to 5435.25
Hi Brian, yup using points with ArrayGem is set up for the next v3 beta - you won't have to do anything custom you will just be able to select point objects in addition to curves for the target objects in the regular command.
5435.27 In reply to 5435.26
Should be very useful! :-)
Show messages:  1-2  3-22  23-27
