Help.....question about blender use with Moi
5430.1
So awhile back, someone mentioned use Blender 2.44 to import lwo files using the Moi script. Well this works, but when you
save it as a blend file and bring it into Blender 2.63, all normals are lost :( Same goes for the old .obj script to correct normals.
Maybe to get a model ready for resale for use in popular 3D software, it requires retopology afterall. If it were just to render a model,
then all would be well in the world of 3d, plenty of renderers out there for that. Haven't tried things like Luxology yet, have and own C4D though. ;)
I get very little time to play with this stuff anymore.
5430.2 In reply to 5430.1
Hi FlashFire, yes there are definitely problems with vertex normals and Blender - Blender just simply ignores vertex normals stored in files and also discards them at other times as well like when doing renderings.
Because of this, Blender is just not very good at rendering CAD data in general.
See here for some previous discussions on this:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5083.6
http://moi3d.com/forum/index.php?webtag=MOI&msg=4515.3
http://moi3d.com/forum/index.php?webtag=MOI&msg=4272.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=4409.79
Well, this problem is pretty much limited just to Blender - all other renderers that I know of are able to read in vertex normals and use them for shading.
For Cinema4D use OBJ format, C4D is able to read in the vertex normals stored in the OBJ file, it will be present as a "normals" tag in the model data.
5430.3 In reply to 5430.2
Hey Michael, Flashfire. I'm new to these forums, but not blender. I use blender to make 3D models for Laminar Research, maker of the flight sim, X-Plane. I have imported several Moi models into Blender and though the vertex normals might be "not as exported", they do exist in Blender and can be recalculated / reset in Blender. There is a command, "recalculate normals outside" and this command straightens up all the normals...assuming no "T-type" face connections with shared verticies that is. In addition, there are some modifiers in Blender, "Edge split" that can be used to "break" shared normals between two adjacent polygons and give you sharp edges where you need it. High aspect ratio polygonal topology can cause artifacts in blender though, so I tend to tessellate with aspect ratios < 4....and adjust in blender if need be. I usually use the *.LWO to go from Moi to Blender. There is no doubt that it does take a few extra steps to "fix and clean" normals from imported geometry compared to other programs but I just wanted to let interested folks know that it can be done and blender can be used for high quality rendering.
-Tom Kyler
5430.4 In reply to 5430.3
Hi Tom,
Certainly they exist, otherwise it would only do "flat" totally faceted looking shading. But instead of importing the accurate vertex normals from the OBJ file, Blender ignore those and will instead create its own ones by averaging polygon data - this process will usually leave some hint (sometimes strongly) of the polygon structure in the shaded results.
The vertex normals that are stored in the OBJ file come from the original NURBS surface data, and so when those are used for shading it greatly helps the shaded result to look exactly the same as the original surface without any extra work required at all. So because of that I very strongly recommend using a renderer that is able to import and use vertex normals properly, it will generate better quality results with no extra work involved.
Someone could look at Bryce or Thea render for some free rendering choices, and also Carrara and SimLab composer are low cost choices.
Pretty much any other renderer than Blender is able to use the vertex normals properly.
Doing this kind of low level polygon repair can be very labor intensive, particularly for someone who does not happen to have any previous experience in polygon modeling and is just looking for a simple to use rendering solution.
I think you're grossly underestimating the amount of work and learning involved to do these additional steps - particularly if someone is not experienced in poly modeling in blender you're talking about a big learning curve involved.
Meanwhile with any other renderer that does import vertex normals properly you just import and render and there are no extra steps involved at all.
So I'd still strongly advise not to use Blender if someone's looking for a simple and easy to use rendering solution for rendering CAD data in particular. If you are familiar with poly modeling in Blender, yes it is possible to get some ok results with extra work involved but for a lot of people that's not a very good solution.
new Blender is released : new format Collada but not news of the vertex normal! ;)
http://www.blender.org/development/release-logs/blender-264/
