Center model on world axis zero coordinates?
All  1-2  3-17
5427.3 In reply to 5427.1
Also I'm planning on adding a mechanism to the Move command to make it easier to set the base point of the move to the center of the object's bounding box.
For now it can be easier to use the Transform > Align command instead since it can use the bounding center within it - it does a 2D type of align using one viewport so you need to do 2 aligns in 2 different viewports and that should then do what you're looking for.
5427.4 In reply to 5427.3
Thanks a lot for the quick reply. Finding the center is exactly my problem so adding such a mechanism to the Move command is quite welcome. Until then the Align method will do.
5427.5 In reply to 5427.4
I think it will be an additional button that will be available in the Move command at the "Pick base point" prompt, the button will say something like "From center" or "From bounding center" or something like that, and when you push it the center of the bounding box around the objects being moved will be used as the base point and then you'll go to the next stage and pick the target point and you would be able to type 0 and push enter there for specifying 0,0,0 as the target.
There is also a command that you can set on a shortcut key that will generate a point object at the bounding box center location, it might be useful to you:
http://moi3d.com/2.0/docs/moi_command_reference10.htm#boundingboxcenter
5427.6 In reply to 5427.5
For setting up stuff for a cnc work offset, I have been using the BoundingBox command which gives me a block to move into place, whether center or various corners to origin.
The new move sounds sweet. Maybe consider some type of option to select the various points of the bounds for the manufacturers side:
Although this could gum up the "sleek and uncomplicated part". It may have to be something for the catchall properties panel. But just wanted to mention this for consideration.
5427.7 In reply to 5427.6
Thanks BurrMan, I didn't know that those BoundingBox commads exist. Very handy.
I tried to make a shortcut:
Shift+C=script:BoundingBox; BoundingBoxCenter;
but get an error
5427.8 In reply to 5427.7
oi martin!
as they are commands, you just have to put
Shift+C=BoundingBox or
Shift+C=BoundingBoxCenter
in.
- marco
5427.9 In reply to 5427.8
Thanks Marco, I thought it is possible to run two comands at once. My bad.
5427.10 In reply to 5427.5
>The button will say something like "From center" or "From bounding center" or something like that
Michael, may I suggest "Pick center of bounding box" or "Pick bounding box center".
5427.11 In reply to 5427.10
Hi Martin,
The tricky part about button text (text going inside an actual push button) is that when it's pretty long it can easily wrap to multiple lines in that narrow side pane area...
I don't worry about that so much with prompt text (the description at the top of the command area that tells you what MoI is expecting for you to enter next), but for push button text it's kind of good to try and make it shorter.
5427.12
Am I wrong or is this what you're looking for ? Center at Origin
http://moi3d.com/forum/messages.php?webtag=MOI&msg=2409.2
And by the way, Michael, is it possible to modify the script to have a "Put on Ground" option ? So that the bottom of the bounding box is automatically placed on the CPlane. (There's a similar tool in Wings3D)
EDITED: 27 Sep 2012 by SCHBEURD
5427.13 In reply to 5427.12
Hi Bernard, I forgot about that previous script, I think that should be a useful shortcut for what Martin is talking about.
It's not easy to add an option to that previous one since it has no UI, it just immediately does an action and then exits.
But I've attached a separate "PutOnGround" command here which you can use instead.
5427.14 In reply to 5427.13
PutOnGround works really well !
Thanks a lot. I will use this one very often !
Happy MoI user since beta version of August 13 2006...
PutOnground : cool
But no possibility to stop the drop if there is an objet on the path ? (like collision)
5427.16 In reply to 5427.15
Nope, this is just a simple positioning script, something that would do comprehensive collision detection would be a much more involved project.
5427.17 In reply to 5427.16
No problem :)
Show messages: All  1-2  3-17
