slf file format conversion
All  1-7  8-18
5410.8 In reply to 5410.1
> If an amateur programmer were to attempt a simple "translation,"
> which 3d format would be easy to convert to, PLY, OBJ, STL...?
Any of those are not too complicated, I would probably recommend OBJ format since it's pretty widespread.
There seems to be a pretty decent explanation here: http://en.wikipedia.org/wiki/Wavefront_.obj_file
And a basic OBJ file can have a pretty simple structure - it's a text file and you'll put in a list of vertices, each vertex will be a line in the text file starting with v followed by x y z coordinates like:
v 0.123 0.234 0.345
v 2.552 5.223 0.251
v 4.223 5.652 2.611
and then to form polygons you make "face" entities after that in the text file. A face can refer to both regular vertices like listed above, and also can refer to texture coordinates and vertex normals. For just basic polygon transfer you can ignore the texture and vertex normals and in that case each face starts with f and then has a list of 1-based (note not zero based) vertex indices. So stuff like
f 1 4 2
f 4 5 1
f 2 5 2
etc...
So all those v lines followed by those f lines will make an OBJ file.
Thank you Michael, Stephen, and Pilou.
5410.10
top mod would be the way to do this kind of things
5410.11 In reply to 5410.10
After posting the .3dm file i thought maybe i should do a little bit with this shape. So i fired up MoI again and separated the shape and used "Inset" on each surface. Hope you like.
5410.12 In reply to 5410.11
Well it gets a thumbs up from me ... Made from the right materials you could have a rehab toy there.
Nice job futagoza
Martin
5410.13 In reply to 5410.11
How was this tetrus created? With T-Splines for Rhino?
5410.15 In reply to 5410.14
So Surface Evolver works by area or energy minimization..., which is what the tetrus is supposed to have.
Little test :)
A rounded filleted triangle on the ground
Sweep a circle
Copy rotate
ArrayCircular *3
Union
5410.17 In reply to 5410.16
@Martin Thank you, much appreciated!
@Brian Yes, i used T-Splines Demo with Rhino Demo.
Well, i could try the Tetrus also with Surface Evolver, but i assume then it would be much thicker in some areas and then i'm not able to run it through T-Splines, because i have never tried to obtain quads out of Evolver...
Best regards
Show messages: All  1-7  8-18
