seems so simple, but...
All  1-6  7-18
5400.7 In reply to 5400.5
Or also another fillet technique that can work in cases where the regular edge-based filleter fails is to break the model apart into individual surfaces, and then select 2 surfaces at a time and do the fillet.
That will perform a surface/surface fillet operation which can sometimes build some fillet surfaces where the edge-based filleting mechanism can get confused.
Another speedy try :)
5400.9 In reply to 5400.6
Hi Peter, and actually probably the easiest way to finish the fillet is to export to a different CAD program that handles that kind of case better than MoI, do it there and then import the file back again.
A couple of programs that can help with that are Autodesk 123D (free: http://www.123dapp.com/123d) or ViaCAD ($99 http://www.punchcad.com/p-9-viacad-2d3d-v8.aspx).
What you'd probably want to do is have the initial shape have all sharp corners initially, like this (also see attached 3DM model file):
Then bring that in to 123D or ViaCAD and do the fillet there along the entire sharp edges - unfortunately this particular case just flat out does not work very well in MoI currently, and using a separate tool for doing it is likely to be the easiest method.
Hopefully more cases like this will work in the future as the people who make the geometry library that MoI uses continue to tune it up. This particular "disappearing fillet" case comes up fairly often so I will ask them about it specifically.
an another :)
5400.11 In reply to 5400.10
Pilou:last one is perfect..Bravo' !
Peter<<Is there any specific reason why you made it so big? (grid is very small on your file) Or that's just coincidence i presume?>>
I did a quick sketch without using your model.I see you are new here so i just show you other alternatives:In future you'll discover many ways to get the same shape
Michael<<Hopefully more cases like this will work in the future as the people who make the geometry library that MoI uses continue to tune it up. This particular "disappearing fillet" case comes up fairly often so I will ask them about it specifically.>>
disappearing fillet is an old problem,i found also bool-diff disappearing and so when model start to be more complex and the build of it is not always correct
while you are improving Moi with new good tools the other people don't run like you..i mean:sometime it's like a Ferrari with just one gallon of fuel in the tank
when the geometry library fails i have a try exporting in 123D to do the same operation,if fails there too i understand i followed a wrong workflow but most of the times it works
so maybe ( i say maybe) could be better to have a stronger library,that is "the core" of a modeling app,than have new tools...but unfortunately it not depends by you
EDITED: 15 Sep 2012 by M-DYNAMICS
5400.12 In reply to 5400.11
Hi Mauro, booleans are generally a strong area in the geometry library that MoI uses, but fillets not so much. Fillets basically have a larger chain of complex operations that they need to perform and so correspondingly there is more that can go wrong.
Basic fillets work pretty well in MoI but things that require special case handling (like disappearing fillet is one example) tend to be problematic.
5400.13 In reply to 5400.10
Very nice Pilou
Peace,
Rich_Art. ;-)
5400.14 In reply to 5400.13
thx all for you help!! Quite nice community in here!
@ Pilou: Is it possible you could very shortly describe what you did, stepswise? It look very interesting!
Kind regards,
Peter
5400.15 In reply to 5400.14
Sure :) But it's only one method, surely so many other!
The key for trim anything is that ;)
A curve (surface, volume) for "trim" a volume!
With Trim = the volume stay "Open"
With Boolean Diff the volume stay "Closed"
Above i have only used a curve :)
PS A circle is sufficient even the Diff Booelan here trim the 2 sides of the piece
Just kill after the function the hole that you don't want (it's 3 clicks if it's an inner wall volume, one click if it's a surface ;)
For avoid that you can take a cylinder :)
EDITED: 16 Sep 2012 by PILOU
5400.16
I have managed to produce the model using extruded solids and fillets.
The shelling was a problem but it can be done by shelling
the base and the top section separately
Hope this of some use.
If you want the file let me know and I will post it.
Barry
Size: 337.3 KB, Downloaded: 133 times, Dimensions: 1024x600px
5400.17 In reply to 5400.16
Allright thank you Pilou! super! I feel like my knowledge has been amplified by 3. I thnk it can be amplified by another 6000, but lets go "step by step" :-)
@ Barry-H: Thank you to! It would be nice indeed to post your file, just so I can learn from it (yeah i'm addicted to knowledge :-) )
Greetz!
P
5400.18
Hi Peter,
attached is the file you requested hope it helps.
Barry
EDITED: 10 Mar 2023 by BARRY-H
Show messages: All  1-6  7-18
