Centre Selection
5392.1
I was wondering if there's a way to centre a selection in a view/views, without zoom to fit?
5392.2 In reply to 5392.1
Hi danperk,
There's a script that can do that here:
http://kyticka.webzdarma.cz/3d/moi/#MoveTargetToObjects
If you set that up on a shortcut key, when you press the key the 3D view will be centered on center of the bounding box of the selected objects but with no zoom change with respect to the current pivot point.
5392.3
Thanks Michael!
Is there any way to have the same function in an active 2D view?
5392.4 In reply to 5392.3
Hi danperk - this version will do it to a 2D view as well:
script: /* Center view on selection, no zoom */ var objs = moi.geometryDatabase.getSelectedObjects(); if ( objs.length > 0 ) { moi.ui.getActiveViewport().targetPt = objs.getBoundingBox().center; }
That will work on either a 2D or 3D view, if you have a maximized view it will do that maximized one and if you're in Split view mode it will do the view that the mouse is currently over top of or the one that was last clicked in if the mouse is not over top of any view at that moment.
5392.5
Great Stuff! Thanks again!
