Feature ideas maybe...
All  1-7  8-14
5387.8 In reply to 5387.7
Hi Mike,
> Michael, you mean Match Edge would'nt work on the edges that are trimmed,
> which is 98% of what my models are made of?
You'll be able to match _to_ a trimmed edge, but the edge being modified will need to be a "natural edge" of the surface.
That's because match will work by a certain kind of surface control point editing, and on a trimmed edge there is not really any particular direct controlling connection between the edge and the surface shape.
On an untrimmed edge the surface and the edge are more implicitly connected together.
> I know it might be silly that I suggested a surface wrinkle "relaxer" tool <...>
That's probably what would be called a "surface fairing" tool and I would like to have that too, it's just probably a kind of lower priority thing that blending and matching.
5387.9 In reply to 5387.8
So the ends of Blends, Fillets, Sweeps and Networks should fit perfectly into that requirement.
Now that I think of it, I sure there's some instance, but I'm having a hard time trying to visualize when two trimmed edges would meet.
Often times, I'll do a procedure where after making two Blend surfaces side-by-side, they don't meet and there is often a gap, overlap or both. Because they are untrimmed natural edges, Match would be able to meet their edges square and tangent(ally) with no need to do any further surgery.
...I like. =-)
5387.10 In reply to 5387.9
Hi Mike, normally you have things meet up at 2 trimmed edges as the result of boolean operations. Most of the regular surface construction methods generate untrimmed surfaces initially, the main expection being Construct > Planar and also end caps on things like extrusions.
5387.11 In reply to 5387.6
Michael,
> I guess I'm not sure how it's any different than setting a CPlane in MoI ?
> Is it because there's some animation that happens during the view movement or something else?
Though SW animates this, it's just decoration that we could do without but what I like about this functionality is that we just need to select a surface or a 3D curve and by clicking this icon, the view switches automatically normal to this surface or curve. I just think it could speedup the workflow.
quote:
I'm not sure about that - the constraint at 19:40 seems to me to be about just making that one particular curve have a horizontal tangent, I don't believe it has anything to do with the entire surface at that particular point yet. It looks like the shape of the entire edge is modified around 21:25 when an additional relation is added to the entire edge - so as far as I can tell the curve constraint that you are referring to at 19:40 does not apply to the entire length of the generated surface just from that alone which is what you seem to be saying?
Your right and again I missed a few things. The main idea though is still about constraint and or relation and especially, in case of curve, we can specify these constraint at each end independently and in the case of surface, we can specify these constraint edge by edge. Now implementing something like that a la Moi may be quite difficult if not impossible without a major shift in what makes MOI a moment of inspiration. I just like this concept of constraint and I'd like to have this in Moi if ever possible.
quote:
At any rate, I do expect to get in a couple of new key tools that would help for doing this kind of stuff - one is an "N-sided blend", which would function fairly differently than the current blend - the current blend works basically similar to sweep where there are 2 rails and the sweep profiles are constructed by blend curves being created between the surfaces. An "N-sided" blend (which is called Fill in that video) will take a closed loop of edges and then fits a larger square surface patch that goes through those and then gets trimmed by those edges. It will actually work more by taking an initial plane surface and deforming that plane until it warps through those boundary edges, so it's fairly different in its construction method than the 2-sided sweep-like current Blend command. The tricky part is to make the plane deform in a nice way and not have things like undulations and ripples in areas where there are not any fit points.
It's not the first time you mention this new "N-sided Blend" command. I'm sure it will be impressive and very useful. When you mention: "the tricky part is to make the plane deform..." it sound like you intend to use some form of iterative process to implement this. Does this mean the library use for this kind of stuff (Solid++ I think) doesn't have a function for this already? Just curious.
Felix
5387.12 In reply to 5387.11
Hi Felix,
Do you mean only the 3D view would switch? Or do you mean the 2D Top view in MoI would switch?
MoI's viewports are set up somewhat differently than SolidWorks, since MoI has the multi-view system where you have separate Top/Front/Right views in addition to the freely rotating 3D view.
If you want to position the Top/Front/Right views, the CPlane tool already does exactly that.
It's overall bad for UI complexity to add in new icons that essentially just do the same thing as an existing tool, that's one way that the UI can easily become bloated and so full of icons that it's no longer easy to find stuff inside of it. Things like that can be implemented as plug-ins though, that may be a better fit for something like this.
I'm still not entirely sure what you are asking for though, because if you want to do 2D work right on that spot of the surface normal like I've mentioned several times the cplane tool in MoI will do that already, and if you don't want to do 2D work right on that spot I don't quite understand what the purpose of the view change would really accomplish.
That fits under what I was describing earlier about a "Match" command that would edit a curve or a surface to be smooth to another object. It will likely be more like an edit tool that adjusts the curve or surface and not quite exactly a "constraint" since constraint sort of implies that it's being used in some kind of history mechanism.
It does sort of have one, but it has the problem that I described earlier that it tends to have quite a lot of undulations in the output surface. So it's not particularly useful as-is.
5387.13 In reply to 5387.12
about this SW "Normal to" command, I understand you might have difficulty understanding what I write, most likely because I have a hard time myself putting what I want to say in words, so I'll try again. When I saw the video I noticed the guy using this tool a few time and I though it would be nice to have one similar in Moi. Yes I know I could setup a shortcut to create a cplane and set it coplanar to the surface or curve I want to view strait on (normal to) and select the view that will show the cplane the way I want. Doing this in Moi represent a certain number of steps, mouse clicks and the works and yes it's not a big deal but I wonder if a command or script could be setup to do all this in as few steps as possible, 2 if possible, 1 to select the object we want to view "normal to" and the other to create the cplane (automatically) and swicth to proper (2D) view. All the work would be done behind the scene by a command or script maybe, that of course is up to you. If you think it's not worth the effort then lets just forget it. Just in case this help you understand a bit more, I usually works in a single view at a time and sometimes I need to setup a cplane to make work easier when the cplane is coplanar to some implied plane of an object I want to work on.
If I understand correctly, with the new N-sided blend command combine with the new match command we will be able to create "a la Moi" surfaces and apply some "matching" continuity with adjacent surfaces. As you noted, this requires a large amount of UI in SW most likely because SW combine (to) many options in all the surface generating commands. I assume the match command would work on any surface which ever way it was created, sweep, loft, revolve, etc. That way you wouldn't have to modify the UI of any of the surface generating commands in Moi. Your a genius!
Thanks for the info about the library.
Regards,
Felix
5387.14 In reply to 5387.13
Hi Felix,
Does this script do what you need? :
script: /* Set cplane and switch to top view */ moi.view.setCPlaneInteractive(); moi.ui.mainWindow.viewpanel.mode = 'Top';
That combines setting the cplane and then automatically switching to the maximized "Top" view after you have placed the cplane.
It's a 2 click process - after you trigger it you can snap the base point of the orientation picker onto the surface you want to be normal to, then after that base point is placed you will be in the orientation picker stage where you can adjust the rotation of the plane if you want, do a right-click in this stage for your second click and then that will do it.
That saves you one single click about setting the view to "Top".
Right now there's no way to avoid the rotation-specifying stage when placing the cplane, but it only takes one right-click in the viewport to accept the default plane orientation, you do not actually have to go over to the "Done" button.
Yup, that's the idea.
Show messages: All  1-7  8-14
