Hard one: Strawberry with flow...
All
1-2
3-5
Mike K4ICY (MAJIKMIKE)
9 Sep 2012 (3 of 5)
5380.3
In reply to
5380.1
Hi Torsten,
This may help:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4549.1
though only academically.
The way you're doing it will cause the pattern to pinch near the poles.
My big suggestion is to avoid the pole areas with and objects (degenerate points/sides). The Flow command has difficulty in those areas.
If you are able to wrap the pattern in the majority of the surface area, you can always use other methods to complete the remaining area.
Visit
K4ICY.com
for my Moi3D tutorials!
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
9 Sep 2012 (4 of 5)
5380.4
In reply to
5380.1
Hi torsten,
> when i try to use a revolved object it either produces garbage, or no result at all.
Could you please post the 3DM model file with the objects that produce the garbage or non-result so I can test with them over here?
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
bemfarmer
9 Sep 2012 (5 of 5)
5380.5
In reply to
5380.1
Worked on a Raspberry a while back, with a little different technique:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5178.1
First you have to count how many seeds in a strawberry :-)
EDITED: 9 Sep 2012 by BEMFARMER
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-2
3-5
