CPlaneNudge shift modifier
5377.1
Hi guys,
Using the CPlaneNudge command as shortcut for direction keys (http://kyticka.webzdarma.cz/3d/moi/)
Is it possible like in Photoshop to use a shift+direction key to nudge by a bigger factor ?
Nudge in Photoshop is by default 1px (1 unit) and when you press shift it goes by 10px increments (10 units)
Would be useful :)
-- shapenoid.com
5377.2 In reply to 5377.1
Hi Desudeus, there are some instructions on that web page for setting up a smaller or larger nudge:
http://kyticka.webzdarma.cz/3d/moi/#Nudge
quote:
and you can also add some more for doing a larger or smaller step, like:
Ctrl+LeftArrow    Nudge Left Large
Alt+LeftArrow    Nudge Left Small
There are a couple of versions of Nudge floating around out there, so make sure you've got the one mentioned right there.
Then you can add the word "Large" or "Small" at the end of the shortcut and that will make the nudge go in either a larger or smaller step.
So put something like: Shift+LeftArrow in the key part, and     Nudge Left Small     in the command part.
5377.3 In reply to 5377.2
edit
5377.4 In reply to 5377.3
Wait it works now, made a typo
-- shapenoid.com
