See where a curve is not closed
5372.1
Another quick question.
Sometimes I struggle to close a curve, maybe because points are not exactly on top of eachother or because there's a small gap somewhere.
Is there a way to zoom to the area where the curve is left open (a zoom between the two end points) using a script/shortcut ?
-- shapenoid.com
5372.2 In reply to 5372.1
Hi DesuDeus - check out here for a plug-in command that you can install called MarkOpenCurveStart - that will place a point object at the start location of an open curve and that will make it easier to identify:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=2888.11
