Interactive 360° ?
All  1  2-5
5367.2 In reply to 5367.1
Are you talking about the "autorotate2" script?
5367.3 In reply to 5367.1
hi there!
you could try something like krpano
http://www.krpano.com/
..they provide tools to generate and viewers to handle panoramic images in the browser. they have a html5 & flash version. easy scriptable via xml .
http://www.krpano.com/docu/html5/
http://www.krpano.com/tools/
check out this example..html5
http://www.krpano.com/krpano.html?xml=tours/corfu/tour.xml&html5=always
really top notch and surprisingly easy to handle. we did some tests earlier this year. generated some panoramic images via modo using a spherical camera. krpano tools took care of the whole conversation process ( cutting into cubical maps, etc...)..there are different plugins to deal with ui and interaction.
http://www.krpano.com/examples/10815/krpano_html5.html
..another solution would be something like a js-framework based thing, like
http://plusquare.pt/Expo360/
http://blog.stableflow.com/jquery-plugins/360-degrees-product-view/
http://www.tripwiremagazine.com/2012/07/jquery-360-degree-image-rotation-plugins.html
~ marco
EDITED: 4 Sep 2012 by MARCO
Allows product color changes. Requires Flash:
http://gardengnomesoftware.com/object2vr_example.php?demo=showcase
Doesn't appear to use Flash:
http://www.keyshot.com/vr/
jQuery 360 product spin:
http://www.ajax-zoom.com/examples/example15.php
http://spritespin.ginie.eu/examples.html
http://www.dopeless-design.de/dopeless-rotate-jquery-plugin-360-degrees-product-viewer.html
http://www.mathieusavard.info/threesixty/demo.html
If you need to change product colors, and Flash is not an option, I'd go for a jQuery solution and hire a developer to add in the features you need. It shouldn't be hard.
5367.5
Hello,
Don't know about panoramas but this product will let you do the material / texture / light changes in real time without having to render each shot.
http://www.motivacg.com/
Show messages: All  1  2-5
