3D system for $4000??
All  1-4  5-11
ZBrush somewhere in the 3D tools box :)
EDITED: 31 Aug 2012 by PILOU
5359.6 In reply to 5359.3
Hi Shaun,
> So my real concern comes down to where to spend money on 3D software that costs $1000 or
> less and the rest on hardware. I forgot to mention I need to import DWG files some how.
The DWG import makes it quite a bit more complex, often times that particular thing is not a focus area for animation and poly modeling software. If you wanted something that definitely included that you could be looking at just Autodesk stuff.
Maybe something low cost like ViaCAD could work as a translator for that DWG part along with something else though.
From what you described for general poly modeling, rendering, and animation I'd guess maybe Modo or Cinema4D might fit.
5359.7
Modo is $995 and does most things out of the box. There are a few things missing compared with Max (Particles, proper hair, etc) but not much. Depends what you are going to use it for. Modo imports MoI objects perfectly.
5359.8
WOW! For the heck of it I downloaded Blender 2.6. I have not seen Blender for some time and based all my assumptions on old information. The new interface is much nicer. It still does things in a bit of an odd way, but even after just an afternoon of messing around I think I could get use to it.
Even the internal renderer isn't that bad. It's better than Max's internal renderer. I tried Yafaray as well and so far so good. Don't know if this will be a "pro" option but I think I could crank out some paying jobs with it after a little learning.
5359.9 In reply to 5359.8
The main problem with Blender is that unlike all other renderers that I am aware of it does not have the ability to import vertex normals along with polygonal data, which is a big problem when trying to render CAD data.
See here for some previous discussions on this:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5083.6
http://moi3d.com/forum/index.php?webtag=MOI&msg=4515.3
http://moi3d.com/forum/index.php?webtag=MOI&msg=4272.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=4409.79
-Michael
5359.10
I wouldn't class Blender's renderers in the same league as Mental Ray, which comes with Max.
5359.11
It depends, Mental Ray is very good at reflecting and refracting. But anti-aliasing/sampling is pretty poor compared to other renderers. IMHO
For example if you have small details like whispy lines or cracks modeled into something you really have to crank the samples up so they don’t flicker during an animation.
Other renderers sample differently so it isn’t an issue. It all depends on what you’re doing.
Show messages: All  1-4  5-11
