File problem
All  1-4  5-8
5357.5 In reply to 5357.4
Hi Tatyana, to use Rescue3DMFile in Rhino, type in that command name and then pick your file, then at the first prompt pick "Recover" and at the next prompt push "Read All" and that seems to find a whole bunch of stuff in there.
I did a quick run under the debugger and one warning message is printed that there is a CRC error in the file - that means that a checksum that was recorded when the file was written does not match the current contents of the file, usually that means the file has been damaged or garbled in some way.
5357.6 In reply to 5357.1
It also might be a good time to worry about whatever device you were using to store these files - if it's an older hard disk it might be dying, if it's something like a thumb drive maybe toss it out and get a new one.
5357.7 In reply to 5357.6
Thankyou very much for help! Rescue3DMFile command recovered all files successfully!
P.S. I'm still in your spam list)
Best regards,
Tatyana.
5357.8 In reply to 5357.7
Hi Tatyana, I'm glad you were able to recover your content!
Normally the spam filter is very good at not bouncing legitimate e-mails but in your case that's what's happening. It could be possible that someone at your same Internet server has been sending spam and has gotten that domain listed on one of the "realtime blacklist" services.
I have now configured the spam service so I think any future e-mails from you should be allowed, sorry for the problem.
Show messages: All  1-4  5-8
