Which rendering application?
5351.1
Hi, I have always used Modo to render objects created in MoI by saving files in the .lwo format and then importing them into Modo. However, the current model I am working on is particularly complex and moving it across to Modo throws up a few issues for me so I was wondering what people around here use to render with? I want to get as good a finish as Modo does if I can.
Look forward to your suggestions
Mark
5351.2 In reply to 5351.1
Hi Mark, what are the particular issues that you are running into with Modo? Quite a few people use Modo to render MoI objects. Maybe the things you are running into can be solved.
One particular note - if you're using Modo 601 then you should set the export options for MoI under Options > Import / Export > LWO options > "Vertex normals style" to actually be "LightWave v10" and not "Modo", since in the new Modo 601 version they changed how they read vertex normals in from LWO files.
That "LightWave v10" option for LWO normals export is available in the MoI v3 beta.
5351.3 In reply to 5351.2
Your advice about changing the way MoI exports as a lwo file certainly helped eliminate some of the odd things. To get a good export I find I have to change the 'angle' from a default of 12 to 4 degrees. This results in much more data but less work for me to do in Modo.
My main problem seems to be in getting the surfaces to join up nicely prior to export. I can select the whole model and run the join command but some surfaces remain separate. Once in Modo I need to sub-divide the model for a very smooth finish and these surfaces pull apart. I can solve this by a) running the merge command on vertices that are within a short distance of one another (100um) but beyond that I need to manually join edges / vertices which is taking a long time.
I guess I need to go back to my model in MoI and figure out how to get those surfaces locked together. Maybe dusing v3beta will help with this.
Mark
5351.4
Hello,
I use TheaRender and am very happy with it. I want something very easy to use that is forgiving but is able to output from multiple render engines in a standalone application, which Thea provides. I also use modo but with every release have been more and more frustrated with not being able to easily get the output right. I'm quite aware that it is probably just how my brain is wired that is incompatible with how modo works. I am actually thinking of moving to Maxon C4D Studio and using the TheaRender plugin since I do need to tweak the polys now and then. I believe that TheaRender also has a modo plugin. I know it has to do more with the artist than the tools but I think individuals like Rich Art do some pretty great renders with C4D.
5351.5 In reply to 5351.3
Hi Mark - you should not try to subdivide the model further in your rendering application, that's not going to work right in any rendering program, the output you get from MoI should just be rendered directly and not really edited further. So if you need more polygons you need to increase the density at export time from MoI, not really afterwards.
You can put in an angle tighter than what the slider is set for if you type the number in directly in the "Angle" field in the mesh export dialog.
Also sometimes if you've got a broad shape that is only shallowly curved the angle division mechanism may not divide things enough for your particular purposes - when that happens you need to use one of the other settings on the mesh dialog, primarily the "Divide larger than" setting. You can enter in a distance value there and any polygons larger than that distance will be further broken down. So for example if you put in a value of 2 it will continue subdividing until polygons are less than 2 units across, that can help to give more detail in areas that have only a shallow curvature to them. When you have shallow curvature it means that there is not much deviation between the surface normals in those areas, and so the anglular measurement which divides things based on the angle between surface normals does not divide things very heavily in areas like that.
The "Divide larger than" setting does not come into play when using the slider, you have to enter in a value directly. The reason for this is that the "Divide larger than" setting is scale dependent - the value you that you enter in there depends on the overall scale of your object. The slider only controls the angular measurement, which is scale independent - it works the same on objects just based on their curvature and not on their size.
This usually means that there is too large of a gap between those pieces, things have to be fairly close (within 0.005 units for a regular sized object) to each other before they can be joined.
Sometimes you can just scale your object down and then join, but other times if you have some kind of chaotic or messy edge structures that are not close enough to one another that might mean the model needs to be repaired or reconstructed in those areas. It's hard to give a good recommendation on what to do on this just in the abstract, I would need to see your file to try and help give you much more specific information on this, if you want you can e-mail the file to me at moi@moi3d.com if you want help with it.
But basically these things you are mentioning re: subdivision and joining are not something that you would solve by going to a different renderer anyway, they sound to me like things that you need to solve on the model in MoI or at export time from MoI with using some more mesh settings.
5351.6 In reply to 5351.5
Thanks Michael, some good advice there. I will send over a copy of the file - or at least the part that is giving me trouble right now during the day.
Mark
