doodling with MoI
All  1-16  17-19
534.17 In reply to 534.16
Hi phlatt5th, that's a nice can-opener result. Nice clean construction!
534.18 In reply to 534.15
Thanks, It's good to know how to locate the c-lines so that you can control the orientation of the cylinder, I can use that for other things, as well... since the correct spacing and over-lap of the objects is crucial to having the model function in metal and real stones, and it's different for every finger size relative to the stone size, it takes some planning to lay these things out anyway, so maybe scaffolding in combination with some c-lines when you need them, would be a good solution.
-Jesse
534.19 In reply to 534.18
Yeah, I think so. There is some overhead to doing the scaffolding (invoking multiple drawing tools, erasing stuff later, etc...) but if you are already spending some time planning things then this overhead is not a problem.
But if you want something quick, for instance just getting a cylinder drawn at the correct orientation at an approximate height or lateral offset location for a type of quick visualization sketch, then clines keeps things moving along really speedily for that type of a thing because placing just one or two clines is super quick and there is no erase time. Like it might take you only 2 seconds to place the quick cline temporary "scaffolding" in place, but maybe something like 10 seconds to place regular geometry scaffolding, especially because for regular geometry scaffolding you have to trigger multiple commands and also possibly move stuff around a bit since you don't have the implicit extensions that clines have built in.
10 seconds versus 2 seconds is not a big deal if you've already spent a few minutes planning stuff out. But if you want to just draw and sketch stuff really quickly, it does become more significant because just a few more seconds starts to take away the rapid "drawing" type feeling...
Show messages: All  1-16  17-19
